lmdew Posted October 3, 2010 Share Posted October 3, 2010 I did a 98 2.5 to 2.2 swap. I sold the car, a few months later, the new Owner said they smelled fuel in the car. I always use the original 2.2 canister up front. I looked over all the fuel lines including the fuel pump and sending unit. I could not find any leaks. Anyone have an idea or had this problem before? Link to comment Share on other sites More sharing options...
davebugs Posted October 3, 2010 Share Posted October 3, 2010 I always replace the fuel filter. So I suppose while you didn't mention it specifically that you did check all 3 hoses up there? I'd check the most prone to leak fuel problem - the filler tube. Doubt it's swap realted since it took so long to be an issue. Just good old dry rot, a critter, or rust(filler tube). Link to comment Share on other sites More sharing options...
lmdew Posted October 3, 2010 Author Share Posted October 3, 2010 Thanks, I'll take a closer look. Yes all the fuel filter hoses are hooked up and are in good condition. Link to comment Share on other sites More sharing options...
