b88185 Posted October 5, 2010 Share Posted October 5, 2010 I've been having some trouble with my Weberized EA82 and can't seem to figure out exactly what the problem is... it runs great except for at a certain throttle opening. Just off idle is OK, but as soon as you open it up a bit more (1/4 throttle ish) it stumbles and runs really rough - almost to the point of quitting. But full or 3/4 throttle seems to be ok. I would guess that it needs to be rejetted, except I had it running PERFECTLY not that long ago. I've had the carb apart on the car, blown out all the jets, idle circuit etc but no luck. No vac leaks that I can find either Anybody have this problem before? Any help would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
b88185 Posted October 10, 2010 Author Share Posted October 10, 2010 Found it - power valve in the carb, diaphragm is shot. Constant dumping of gas regardless of vacuum = bad. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 11, 2010 Share Posted October 11, 2010 Power valve failure on the Webers is pretty rare. Glad you found it. GD Quote Link to comment Share on other sites More sharing options...
b88185 Posted October 22, 2010 Author Share Posted October 22, 2010 Aaaand it turns out it wasn't the power valve. Still ran like crap, so tried removing valve and plugging its vac hole. Still ran like crap, so it seems that the power valve wasn't at fault. Another interesting tidbit: when I open just the 38mm barrel it revs smoothly. So it has something to do with the 36... Might try changing out the jets in that one, unless there could be a vac leak on that barrel only? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 22, 2010 Share Posted October 22, 2010 Have you cleaned out the air bleed and emulsion tube on the primary? Might have sucked something down in there. Sounds like the e-tube isn't working and you aren't getting a nice even spray pattern at the higher end of the venturi pressure.... GD Quote Link to comment Share on other sites More sharing options...
b88185 Posted October 23, 2010 Author Share Posted October 23, 2010 I've blown it out with carb cleaner several times now, but may as well try again. The spray pattern definitely doesn't look consistent if you check down the barrel at part throttle, should it be an even spray? It's more like dripping than a mist. Full throttle looks even. Quote Link to comment Share on other sites More sharing options...
b88185 Posted October 23, 2010 Author Share Posted October 23, 2010 Took apart the carb, swapped jets, cleaned out bleeds etc. and no change. I did find the problem though, and it had nothing to do with the carb... Noticed that the coil was arcing, went through the ignition system. Turns out my disty was destroying itself from the inside out - the rotor had come mostly loose and started chewing everything up in there. I ghetto-rigged it back together, and everything runs smoothly!! Just gotta find myself a new disty. Now on to that TOD... Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 23, 2010 Share Posted October 23, 2010 Don't just blow it out with carb cleaner - pull the e-tube out and really get it clean. Use a bit of bent wire (paper clip works) to pull the e-tube out of it's bore. Yes - the spray pattern should always be even - dripping, etc is a sign of some kind of problem with the circuit. GD Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 23, 2010 Share Posted October 23, 2010 Excelent! Glad you found it - the spray pattern was probably due to poor/uneven manifold vacuum. GD Quote Link to comment Share on other sites More sharing options...
MilesFox Posted October 24, 2010 Share Posted October 24, 2010 Bring yourself around the garage today if you have time. I would like to see the weber and contemplate the same for my 3-door:banana:I might have a disty part around although i have thrown a lot of that stuff out. Quote Link to comment Share on other sites More sharing options...
b88185 Posted October 24, 2010 Author Share Posted October 24, 2010 I've got to drive down to Burlington today and will probably be back up here around 4pm, if you're still around then I could stop by Picked up a rotor at O'Reilley's this morning for all of $5, problem solved. Quote Link to comment Share on other sites More sharing options...
