gar52hpny Posted October 6, 2010 Share Posted October 6, 2010 I just started the 2002 outback 2.5 with a cold engine and cold coolant, almost immediately I heard a click and the cooling fans started for about 10 seconds then turned off. That happened several times before I turned the engine off. I had heard the click previously but the short cycle seems to be new. Does anyone have any ideas what that means? Thank you... Gary Link to comment Share on other sites More sharing options...
OB99W Posted October 6, 2010 Share Posted October 6, 2010 One possibility is a defective engine coolant temperature sensor. If you have access to an OBD-II scan tool, you could check the live (real-time) data with the engine cold and see what temp is indicated. If it's not near to the ambient temp, the temp sensor might be bad. However, check first for corrosion at the connector before considering replacement. Link to comment Share on other sites More sharing options...
94Loyale Posted October 7, 2010 Share Posted October 7, 2010 Are you running the defrost or AC? Link to comment Share on other sites More sharing options...
OB99W Posted October 7, 2010 Share Posted October 7, 2010 94Loyale said: Are you running the defrost or AC? Good question. Link to comment Share on other sites More sharing options...
gar52hpny Posted October 7, 2010 Author Share Posted October 7, 2010 Not running AC or DEFROST... Thank you.... Link to comment Share on other sites More sharing options...
