abeattie220 Posted November 1, 2010 Author Share Posted November 1, 2010 so trannys in engines in but it wont start with the ignition totally dead stick it will fire right up if i jumper the starter strait to battery and stay running but at 2000 rpm i have the park switch jumpered out and i know i need to ground the AT/MT pin on the PCM but im still not sure what one it it is and is this whats causing my no ign start and high idle condition? also i just got it in and only had the head pipes on it so no O2 sensors or back pressure i dunno if that makes a difference Link to comment Share on other sites More sharing options...
Numbchux Posted November 1, 2010 Share Posted November 1, 2010 sounds like you don't have the neutral start switch shorted correctly. ECU has no control over starter circuit. Link to comment Share on other sites More sharing options...
abeattie220 Posted November 17, 2010 Author Share Posted November 17, 2010 almost done just waiting on custome drive shaft LSD installed and front axles spliced (by me) Link to comment Share on other sites More sharing options...
Yo'J Posted November 17, 2010 Share Posted November 17, 2010 park switch? Link to comment Share on other sites More sharing options...
abeattie220 Posted November 17, 2010 Author Share Posted November 17, 2010 right now i have the auto inhibitor switch wired in and in the neutral position just so it will start for now but eventually im goining to jumper it and eliminate and replace with a clutch start switch on the dash Link to comment Share on other sites More sharing options...
abeattie220 Posted November 26, 2010 Author Share Posted November 26, 2010 anyone know the pin number and wire color of a 95 impreza ecu AT/MT identifier wire or have an ecu schematic for for that yr Link to comment Share on other sites More sharing options...
Gloyale Posted November 26, 2010 Share Posted November 26, 2010 Pin 50 Grounded for MT Ungrounded for AT. Link to comment Share on other sites More sharing options...
abeattie220 Posted November 30, 2010 Author Share Posted November 30, 2010 sweeet thanks man Link to comment Share on other sites More sharing options...
what huh Posted December 1, 2010 Share Posted December 1, 2010 Numbchux said: front axles are also an issue. the axle stubs on the D/R are 23-spline, and your imprezas are 25-spline. Again, you might be able to make some hybrid axles with what you have, or '93-'94 MT imprezas have 23-spline inner axles. so this means that the '93-'94 impreza front axles can be use in a '95-newer impreza to allow the ea tranmission to match up the ej hubs? Link to comment Share on other sites More sharing options...
Gloyale Posted December 1, 2010 Share Posted December 1, 2010 what huh said: so this means that the '93-'94 impreza front axles can be use in a '95-newer impreza to allow the ea tranmission to match up the ej hubs? Yup. Pretty sure that it works for Legacy/Imp/Forrester. But 2wd Imp axles are pretty weak compared to the newer Outback and Forrester axles. For a heavy Outback or Forrester, or really any EJ chassis, it'd be better to put 25 spline stubs into the EA trans/front diff. Link to comment Share on other sites More sharing options...
what huh Posted December 1, 2010 Share Posted December 1, 2010 Gloyale said: But 2wd Imp axles are pretty weak compared to the newer Outback and Forrester axles. For a heavy Outback or Forrester, or really any EJ chassis, it'd be better to put 25 spline stubs into the EA trans/front diff. how does that work Link to comment Share on other sites More sharing options...
Numbchux Posted December 1, 2010 Share Posted December 1, 2010 what huh said: how does that work you have to split the transmission case. no small project. IMHO not worth it to just swap axle stubs. I don't know, I haven't actually run the 23-spline EJ axles, but I have seen them in person, out of the car. they don't seem terribly under-built. I think if they were run at a reasonable angle and you didn't abuse them too badly, they'd probably hold up fine. Link to comment Share on other sites More sharing options...
Gloyale Posted December 1, 2010 Share Posted December 1, 2010 Numbchux said: you have to split the transmission case. no small project. IMHO not worth it to just swap axle stubs. Once you've done it a few times, it's not that hard. I recently needed an adapter plate for a friends swap. I don't have any on hand right now......except the one in my 89 GL w/ single range 5spd. SO.....we pulled the trans, split it, stuffed the guts into the case halves from a Legacy, and put it all back toghether. Pulling and reinstalling the the trans was the hard part. Splitting the cases, and swapping parts and bolting them up took about 2-3 hours. It could be even quicker if you are JUST swapping stubs. It may not be worth it for an Imp, being as they are pretty light. But to put an old D/R into a Legacy/Outback/Forrester, I would want to keep those cars axles and make the trans 25 spline to fit. Link to comment Share on other sites More sharing options...
abeattie220 Posted December 3, 2010 Author Share Posted December 3, 2010 reworked driveshaft came in today installed first test drive went great snowy roads. have some bugs to work out like speedo cables bein diffent and the torque stopper but all in all drove pretty good Link to comment Share on other sites More sharing options...
Gloyale Posted December 4, 2010 Share Posted December 4, 2010 The EJ pitch stopper bracket will bolt right onto the EA trans. Speedo cable should be a direct fit. The hole in the side of the trans will accept either a cable, or a sensor....not sure which you're 95 Imp has, but it should be a direct fit for either. Link to comment Share on other sites More sharing options...
abeattie220 Posted December 5, 2010 Author Share Posted December 5, 2010 mine has a cable and the ea trans has a female cable twister thingy and the imp has a female cable as well it will screw into the hole but i dunno if it will doin anything have to investigate Link to comment Share on other sites More sharing options...
Gloyale Posted December 6, 2010 Share Posted December 6, 2010 Just hook it up. 17mm wrench. Tricky part is getting the tab to fit into the slot. Once you get that, the outer hub will seat a to the threads and you can screw it in. Link to comment Share on other sites More sharing options...
abeattie220 Posted January 7, 2011 Author Share Posted January 7, 2011 yah the tab isnt there on my impreza just like a recessed square drive and we are up to almost a thousand miles with no reportable issues other than no speedo/odo LSRD is amazing for gettin it on snowy roads Link to comment Share on other sites More sharing options...
