211 Posted October 8, 2010 Share Posted October 8, 2010 I have the whole Service Manual for 2000 Legacy but there seems to be a page missing in the On-Car Service Section. The last page I have goes into valve adjustment detail but the last step is step 6) Remove timing cover. then that's it, last pdf in the folder This is on pg 8 (aka MSA5TCD00L16109) in the path: Service Manual> ENGINE SECTION> On Car Services Logic would dictate the next pdf would be MSAxxxx6110 but I did a search through the whole directory and there is no 6110. It goes 6109 to 6111 I'm in the process of combining all these MSAxxxx files into one PDF per section. The Valve section is important... Link to comment Share on other sites More sharing options...
OB99W Posted October 8, 2010 Share Posted October 8, 2010 It's probably covered in the manual on Josh's server: http://www.main.experiencetherave.com/subaru_manual_scans/2000+_Legacy_FSM/ Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 8, 2010 Share Posted October 8, 2010 Feeler gauge and a wrench - pretty simple valve adjustment on those. You just set the clearance between the rocker and the valve stem (with the valve unloaded) and lock the adjuster with the jam nut. 8 thou on the intake and 10 on the exhaust. GD Link to comment Share on other sites More sharing options...
