johnceggleston Posted October 8, 2010 Share Posted October 8, 2010 97 GT, 2,2L swap, auto w/ 150k miles. the hor, cruise control quit working and i have an ABS light on all the time. i expected a fuse, but these things are on different fuses and i have check them all. what do they have in common, the steering wheel? suggestions? Quote Link to comment Share on other sites More sharing options...
OB99W Posted October 8, 2010 Share Posted October 8, 2010 John, start by rechecking fuses, specifically #18 in the interior fuse box (10A, center one in bottom row). It's common to the ABS and cruise control modules. The roll spring is common to the cruise and horn. Theory: I wonder if a problem in the steering wheel might have taken out that fuse. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted October 8, 2010 Author Share Posted October 8, 2010 John, start by rechecking fuses, specifically #18 in the interior fuse box (10A, center one in bottom row). It's common to the ABS and cruise control modules. The roll spring is common to the cruise and horn. Theory: I wonder if a problem in the steering wheel might have taken out that fuse. will do , thanks i have never pulled a steering wheel, i'm hoping i don't have to, but we'll see. Quote Link to comment Share on other sites More sharing options...
OB99W Posted October 8, 2010 Share Posted October 8, 2010 I meant to say "clock spring/roll connector", not "roll spring" I need more sleep. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted October 8, 2010 Share Posted October 8, 2010 will do , thanks i have never pulled a steering wheel, i'm hoping i don't have to, but we'll see. Insert a new fuse in the holder, even though the existing fuse does not look blown. I have had the spades on a fuse or in the holder get dirty, and cause a bad connection to the fuse. I used a sliver of emery board to clean the fuse holder insert portion, as well as to clean the spades on a fuse. This did fix my problem. You don't even want to think about pulling the steering wheel, but If you have to, be sure to learn all there is know about how to disconnect the steering wheel air bag. You do not want the air bag to blow up, while working on the steering wheel. Quote Link to comment Share on other sites More sharing options...
bstone Posted October 8, 2010 Share Posted October 8, 2010 Get test light. Check fuses. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted October 8, 2010 Author Share Posted October 8, 2010 (edited) so i will be not the guy who swears "the fuses are good, i checked them" i will check them again. but to have a bad fuse after my method of checking fuses would require 2 bad fuses in a row, or a bad fuse seat. i start with a spare fuse that looks good. when i pull a fuse i replace it with the spare. if nothing changes i move on to the next, pull it and install the one i pulled from the first . keep doing this until i have covered all of the fuses of that size. on to the next size. the fuses that kill something when pulled are obviously good. the ones that do nothing may need further checking. i guess a test light would come in handy. but i'll check again. i have read too many posts where the cause is a bad fuse after checking all the fuses. Edited October 8, 2010 by johnceggleston Quote Link to comment Share on other sites More sharing options...
bstone Posted October 8, 2010 Share Posted October 8, 2010 so i will be not the guy who swears "the fuses are good, i checked them" i will check them again. but to have a bad fuse after my method of checking fuses would require 2 bad fuses in a row, or a bad fuse seat. i start with a spare fuse that looks good. when i pull a fuse i replace it with the spare. if nothing changes i move on to the next, pull it and install the one i pulled from the first . keep doing this until i have covered all of the fuses of that size. on to the next size. the fuses that kill something when pulled are obviously good. the ones that do nothing may need further checking. i guess a test light would come in handy. but i'll check again. i have read too many posts where the cause is a bad fuse after checking all the fuses. That's a labor intensive way of checking fuses. Just get a test light. They sell them at AutoZone real cheap. Quote Link to comment Share on other sites More sharing options...
OB99W Posted October 8, 2010 Share Posted October 8, 2010 If all the ABS-related fuses are good, then I'd suggest reading the ABS code(s). In general, a continuity tester could prove useful. Quote Link to comment Share on other sites More sharing options...
wtdash Posted October 8, 2010 Share Posted October 8, 2010 (edited) 99.9% sure it's the roll-connector/ clockspring...same EXACT symptons on my '98 Forester - no Horn/Cruise/ABS light on. Replaced the CS and back in business. Pulling the steering wheel isn't that tough...getting the damn airbag connectors apart and fishing the harness wires out was a PITA though. You'll have no problem w/it. Couple of links for reference #1 and #2....may have to register (free) to see all the pics. GL, TD Edited October 8, 2010 by wtdash Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted October 8, 2010 Author Share Posted October 8, 2010 99.9% sure it's the roll-connector/ clockspring...same EXACT symptons on my '98 Forester - no Horn/Cruise/ABS light on. Replaced the CS and back in business. Pulling the steering wheel isn't that tough...getting the damn airbag connectors apart and fishing the harness wires out was a PITA though. You'll have no problem w/it. Couple of links for reference #1 and #2....may have to register (free) to see all the pics. GL, TD thanks td, just what i needed. Quote Link to comment Share on other sites More sharing options...
