SubaRube Posted October 8, 2010 Share Posted October 8, 2010 My EGR passages are completely clogged. Is there any good ways to clean 'em without removing the manifold and soaking it? Does the speedo cable on the drill really work or should I not waste my time? Can't pass smog 'til I can get it cleaned out. Link to comment Share on other sites More sharing options...
Petersubaru Posted October 8, 2010 Share Posted October 8, 2010 (edited) My EGR passages are completely clogged. Is there any good waysto clean 'em without removing the manifold and soaking it? Does the speedo cable on the drill really work or should I not waste my time? Can't pass smog 'til I can get it cleaned out. ..pushing or reaming a hardened material into the intake manifold my not be good for the pistons..or you might just get lucky by taking a small screw driver to scrape the surface of the clogged hole..maybe you will not have to go any deeper.. Edited October 8, 2010 by Petersubaru Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 8, 2010 Share Posted October 8, 2010 Why you Won't take off the intake Manyfold? ... I Believe it's the Best way to Clean all that Stuff. Kind Regards. Link to comment Share on other sites More sharing options...
SubaRube Posted October 8, 2010 Author Share Posted October 8, 2010 I don't have anywhere to do the work for one. And honestly, I'm too busy to wrench on my car at this point in time. I might just try to get a second manifold for cheap so I can just swap it out when ready. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 19, 2010 Share Posted October 19, 2010 I Believe that if you Might find the Time to Take Off the intake Manyfold to do a Swap... You Might Wash out Clean the one you already have, instead of a Swap... I Washed my EA82's intake when I Did the Weber Swap... ...and it is Still Clean! Link to comment Share on other sites More sharing options...
