blacklabel Posted February 25, 2004 Share Posted February 25, 2004 I have a 87 GL wagon... its a 1.8 caburated 5-speed 4x4. What kind of mods can i do to make it faster? I am new to the car thing so simpler things at first would help the most. Air intake? Install turbo? I really dont know what to do.. help:( Link to comment Share on other sites More sharing options...
ru4x4ever Posted February 25, 2004 Share Posted February 25, 2004 Welcome to the board and im sure you will find all you need here. Maybe try a modified air intake , exhaust and get bigger plug wires and good coil. That would be a good start. -Sean Link to comment Share on other sites More sharing options...
blacklabel Posted February 25, 2004 Author Share Posted February 25, 2004 where can i find these things to fit my soob? i look around online but i dont know neccessarily what to look for and what will work Link to comment Share on other sites More sharing options...
ru4x4ever Posted February 25, 2004 Share Posted February 25, 2004 You probly can cut bottom of stock air box and get a K&N replacement filter, or take off stock airbox and make or find an adapter to put a cone style filter on. This will let your car breath. Link to comment Share on other sites More sharing options...
bushbasher Posted February 25, 2004 Share Posted February 25, 2004 your carby wagons not gonna be a speed demon, but cutting up your air filter box to allow better flow through the filter would be a start. Then get rid of the choking stock muffler and replace it with a performance muffler of your choice. For more gains you could redo the exhaust from the cat back. If thats not enough you can upgrade to a weber carb, which would set you back around $3-400. This would probably be the biggest improvement. Then theres ignition: Get a performance coil and wires, gap your plugs .45-.5. As for the turbo idea, best not to venture into a project like that if you're new to working on cars. If you want a quick suby you'll want to find a turbo RX or XT. Do a search on these items and you'll probably come up with more detail. Link to comment Share on other sites More sharing options...
blacklabel Posted February 25, 2004 Author Share Posted February 25, 2004 i guess now that I think about it, what i want to be doing is more rallying type mods.. so i guess functionality and power is what i am looking for over speed... does the k&m filter make that much of a difference? Link to comment Share on other sites More sharing options...
Turbone Posted February 25, 2004 Share Posted February 25, 2004 Not unless you have a Weber to go with it. There is no airbox (Turbo, MPFI,SPFI only) mod on a carbed Soob either, it has a standard aircleaner on top of the carb. Get some good tires if you want to RallyX. Plug wires and a hotter coil will help, along with the exhaust. Link to comment Share on other sites More sharing options...
blacklabel Posted February 25, 2004 Author Share Posted February 25, 2004 yea my exhaust is busted to hell... i guess the good thing about this car being a project is that since i got it for free, spending money on it isnt as big of a deal... any suggestions for exhaust? ive thought about just picking up a cherry bomb for now but im skeptical because of the hype Link to comment Share on other sites More sharing options...
calebz Posted February 25, 2004 Share Posted February 25, 2004 gap your plugs .45-.5. :eek: Thats a huge gap.. Why not try something a little more conservative like .045-.050 Link to comment Share on other sites More sharing options...
blacklabel Posted February 25, 2004 Author Share Posted February 25, 2004 alright.. i got a good list of things to start with and ive found stuff online that will work. this will set me back some $$ but its worth it. Will changing out the carb be very hard? should i have a pro do it? thanks for all the advice and keep it comin Link to comment Share on other sites More sharing options...
ru4x4ever Posted February 25, 2004 Share Posted February 25, 2004 My bad i was ASSUMEing it was it was fuel injected. Link to comment Share on other sites More sharing options...
raverjames21 Posted February 25, 2004 Share Posted February 25, 2004 Originally posted by blacklabel alright.. i got a good list of things to start with and ive found stuff online that will work. this will set me back some $$ but its worth it. Will changing out the carb be very hard? should i have a pro do it? thanks for all the advice and keep it comin If you have some mechanical know how it is simple to swap the carb. Stock carb is simple to remove/install and the weber has even less to it than the stock. If you are the type of person that goes to the grease monkey to have your oil changed I would not suggest you attemp the job. Maybe the best thing is for you to meet up with someone who has done a carb swap before. This way nothing gets messed up and you gain some experience. Link to comment Share on other sites More sharing options...
blacklabel Posted February 26, 2004 Author Share Posted February 26, 2004 yea i got some people i know.. i have some basic mechanic skills so it sounds like itll be good Link to comment Share on other sites More sharing options...
MilesFox Posted February 26, 2004 Share Posted February 26, 2004 cherry bombs are good, cheap, and i swear by them you could tackle swapping the carb yourself, and have the pro just tune it in, save on labor costs. just remember, anything hands on you do with your car, just ask about it here, you will be sure to get some excellent expertise! Link to comment Share on other sites More sharing options...
blacklabel Posted February 26, 2004 Author Share Posted February 26, 2004 would it be possible to pull a turbo from a junked sooby of the same year and get it installed in mine or does a turbo require a fuel injector Link to comment Share on other sites More sharing options...
blacklabel Posted February 26, 2004 Author Share Posted February 26, 2004 oh yea and where can i find a good/cheap coil that works for my soob Link to comment Share on other sites More sharing options...
blacklabel Posted February 26, 2004 Author Share Posted February 26, 2004 would this work on my car? http://www.hutch-pagan.com/MSD%20coils%20pg%20109.htm Link to comment Share on other sites More sharing options...
blacklabel Posted February 26, 2004 Author Share Posted February 26, 2004 what about a MSD Blaster High Vibration Coil? would it be compatable? Link to comment Share on other sites More sharing options...
MilesFox Posted February 26, 2004 Share Posted February 26, 2004 as far as turbos, it would be better and more economical to swap in an entire turbo motor. the motor swap its self will be all bolt-in, but you will have to get heavy-duty into the electrical, to wire in the ecu and harness that came from the car the turbo motor came form you would have to swap the whole motor, because the turbo intake is dual ports, and will not bolt up to the carb motor. get the accel super stock coil, about 30 bucks. you can gap the plugs to .045-.050, and run one of theose "custom fit" cut to length make your own accel 8mm wire sets, about the same price Link to comment Share on other sites More sharing options...
blacklabel Posted February 26, 2004 Author Share Posted February 26, 2004 thanks for the advice but would it be possible and how hard would it be to install a turbo and what about that MSD coil? Is it compatable or no? Link to comment Share on other sites More sharing options...
torxxx Posted February 27, 2004 Share Posted February 27, 2004 if you want a turbo, buy a turbo motor. From what has been said on the board, its easier to just get a turbo'd motor. If you really want to go this route, The Scooby started a post sometime last week about puttin a turbo on his carbbed wagon. Theres good info there.. Check it out Link to comment Share on other sites More sharing options...
subiemech85 Posted February 27, 2004 Share Posted February 27, 2004 I have a 87 GL wagon... its a 1.8 caburated 5-speed 4x4. ru4x4ever My bad i was ASSUMEing it was it was fuel injected. my 85 wagon 10 spd 4x4 with the hitachi carb and dist seems to enjoy: removal of emissions controls, 2" single pipe mandrel bent from y-pipe to the glasspack, accel 8140C coil NGK plugs vac advance connected directly to intake manifold, and the cheap gas with 10% etaonol! no need to buy a "CHERRY BOMB" name brand muffler:madder: Link to comment Share on other sites More sharing options...
blacklabel Posted March 8, 2004 Author Share Posted March 8, 2004 its aalllllll about the money at this point... any tips on replacing the exhaust system on my car (money, difficulty, etc.)? i dont mean the whole thing, just the pipes are a wee bit rusty and worn out Link to comment Share on other sites More sharing options...
ocsike74 Posted March 8, 2004 Share Posted March 8, 2004 Here in romania we are thinking like this: do the best you can but with less money. So if you are thinking to the exhaust system, try to use some 50 mm internal diameter thin tube and if you have some basic skills and one acetylene welding system youcan do everything yourself. If you want to do something COOL try to use stainless steel tubes and rear and middle silencer. You will hear some kind of engine noise like people with Remus exhaust system. And you wount have problem with corrosion. In my 87' glw Coupe I changed the air filter element with another one who permittes to the engine to absorb much easily the air and the diferense is considerable. Link to comment Share on other sites More sharing options...
blacklabel Posted March 18, 2004 Author Share Posted March 18, 2004 does anybody know a good online store where i can find some parts for my sooby? im finding parts left and right but im never sure if it will work with my GL Link to comment Share on other sites More sharing options...
