NO compression in one cylinder?
Do a wet compression test. Put a couple tablespoons of oil into the cyl. and then do the test. if all of a sudden you have compression, may not be to spec but still better then before, then you have bad rings. you may already know this but i thought id chime in just in case.
Mike
i think the head may have dropped a valve seat, as i ahve seen a few examples
suppose if you pulled the head, you could have it staked back in? i have read in auto books about staking valve seats
so it may be worth it to ask about that to your local machine shops, get their opinions...
