OREchipmunk78 Posted October 13, 2010 Share Posted October 13, 2010 Well heres a dumb question but I'm still new to Subies so here goes: would a subtle solutions 1" 02-07 impreza lift fit on my 87 gl wagon? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 13, 2010 Share Posted October 13, 2010 No - not even close. Totally different platforms. GD Link to comment Share on other sites More sharing options...
OREchipmunk78 Posted October 13, 2010 Author Share Posted October 13, 2010 Thanks again Rick I just saw some on CL and it made me wonder Link to comment Share on other sites More sharing options...
Numbchux Posted October 13, 2010 Share Posted October 13, 2010 actually.....the fronts would work. the 3-bolt EJ strut top pattern is only slightly different than the EA82 one. a few minutes with a dremel (seriously, less than a mm on each hole) and it would work. http://www.subtle-solutions.com/product_info.php?cPath=21_23_35_86&products_id=98 BUT, since there's no camber correction, it would push the strut tops out a bit from the center of the car, which would give it even more positive camber.....yikes. And, it would only be the front. Link to comment Share on other sites More sharing options...
bheinen74 Posted October 13, 2010 Share Posted October 13, 2010 ^ | wow no offset. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 13, 2010 Share Posted October 13, 2010 Yeah - totally lame. GD Link to comment Share on other sites More sharing options...
Numbchux Posted October 13, 2010 Share Posted October 13, 2010 bheinen74 said: ^| wow no offset. that's pretty common for just 1" spacers. since EJ cars have a camber adjustment between the strut and knuckle. Link to comment Share on other sites More sharing options...
daredevil1166 Posted October 13, 2010 Share Posted October 13, 2010 bheinen74 said: ^| wow no offset. I'm not surprised. I have 2" lift blocks and I have no camber issues. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted October 14, 2010 Share Posted October 14, 2010 Also: The Greater Axle Workin' Angle will Destroy the CV Joints 10X Faster or So... Link to comment Share on other sites More sharing options...
bratman18 Posted October 14, 2010 Share Posted October 14, 2010 They work great for the newer ones that they are made for!! I have been running the Jackson Rally version for a while on my 2000 OBS with no issues Link to comment Share on other sites More sharing options...
GeneralDisorder Posted October 14, 2010 Share Posted October 14, 2010 Yeah - if you have adjustable camber (EJ's) then it's not as much of an issue. It's a fail on the EA's though. GD Link to comment Share on other sites More sharing options...
