RMVR53 Posted October 16, 2010 Share Posted October 16, 2010 (edited) actually, got spark but no fire. Belts are in time/have timing/spark checked with a timing light but it wont fire. Even sprayed carb cleaner into the throttle body but it wont light anything. Ideas? Bill Edited October 16, 2010 by RMVR53 Link to comment Share on other sites More sharing options...
AWD TURBO! Posted October 16, 2010 Share Posted October 16, 2010 how did you do your timing (with the cam timing marks!!) and is it TDC with the rotor pointing to #1? Link to comment Share on other sites More sharing options...
RMVR53 Posted October 16, 2010 Author Share Posted October 16, 2010 timing/cam marks on the belt are on. Timing is set at 20BTDC Link to comment Share on other sites More sharing options...
RMVR53 Posted October 17, 2010 Author Share Posted October 17, 2010 just pulled a plug and grounded it...VERY weak spark...almost yellow with a tint of blue... coil? Bill Link to comment Share on other sites More sharing options...
RMVR53 Posted October 17, 2010 Author Share Posted October 17, 2010 (edited) lowest Ohm setting on my meter is 20 and primary reads between .9 and 1 secondary reads 10,500 thoughts? Edited October 17, 2010 by RMVR53 Link to comment Share on other sites More sharing options...
Cougar Posted October 17, 2010 Share Posted October 17, 2010 I doubt the problem is due to a weak spark. I suspect the real trouble may be due to valve timing. Have you checked the compression of the cylinders yet? If not, I suggest you do that to see if the valve timing is ok. Link to comment Share on other sites More sharing options...
RMVR53 Posted October 17, 2010 Author Share Posted October 17, 2010 I figured I talk about a GL because thats where the dizzy/parts came from. This is actually my non-turbo XT that I'm converting to a 2 wire dizzy and single Mikuni PHH carb on a custom manifold. It runs for about 30 seconds on the 4 wire dizzy before the timing starts jumping all over the place (watching with a timing light AND watching the tach). So I know the engine runs...quite well...for that 30 seconds. When I installed the 2 wire dizzy, it won't hit/fire on anything flammable. The dizzy came out of a running car. With this in mind, I'm beginning to think that all my previous problems were coil related..even tho it was/is a new coil its got a problem Bill Link to comment Share on other sites More sharing options...
Cougar Posted October 17, 2010 Share Posted October 17, 2010 If there is an ignitor in the circuit (pretty sure there is one) then you might try replacing it. They go out often. Link to comment Share on other sites More sharing options...
RMVR53 Posted October 18, 2010 Author Share Posted October 18, 2010 are you talking about the transister on the small bracket next to the coil? Link to comment Share on other sites More sharing options...
Cougar Posted October 18, 2010 Share Posted October 18, 2010 Yes, that's it. Link to comment Share on other sites More sharing options...
