What transmission do I need?
Any of the 5spd 4wd trans will fit the same with the same bellhousing conversion kits. Beware of turbo trans since they have a 25 spline axle, which does not fit for the brat. It is possible to swap out 23 spline axle stubs in a turbo(dual range rx) trans to be compatible with the brat axles.
By this route, i would recommend the xt6 trans for regular street driving, having gearing more suited to the ej22 135 hp since the xt6 has 145 hp
