EJ20G : I had a cel code 32 - oxygen sensor. Replaced it
Reconnected battery and turned key on, no more 32 BUT I have a code 21 now and the car runs worse than before. Code 21 is Coolant temp sensor. Why does it make this car run so crappy and where is it Under the mani or is it under the altenator?
And if it is bad can I snag one off a ej22? Or do I have to locate a jdm parts house?
Edited by mx4life
I don't know specifics of the EJ20G, so the following is based on USDM EJs.
The sender near the alternator is for oil pressure.
The temperature sensors are on the coolant pipe. There are two -- the one with a single wire is for the gauge, the one that the ECU reads has two wires.
If you replaced the sensor with a good one, then I would test the connections and the circuit itself for shorts or grounds. Was there any corrosion on the sensor connectors when you replaced it? You could even test the sensor you got just to make sure it works, then if it does work, then it is probably a short/ground somewhere in the circuit.
It runs crappy because the computer defaults to running the motor "choked" when it can't find the sensor I believe, so that's why it runs rich and like crap.
Ok, I will check things tomorrow. It was just weird to me that it came on right after I did my O2 sensor. And It wont clear. If all else fails I printed out the ECU pin layout and I can directly run fresh wire to the sensor to see if thats a fix. also code 49 is popping up and wont clear either. dont understand where these gremlins are coming from
Not to state the obvious or be too much of a smartarse, but usually when a code doesn't "clear" its because you haven't fix the problem ;)
Here's a good link to Legacy777 site on the ECU:
http://www.surrealmirage.com/subaru/engine.html
Good stuff to know, and most likely applies to you, but I am not sure with the EJ20G, so keep that in mind.
Code 49 "Use of improper air flow sensor". Get the proper air flow sensor and that code will go away :) Again, see above.
Let us know what happens after testing all the stuff!
Just curious, how long have you had the car? Could someone have swapped in the wrong ECU in the past? That's a reach I know but maybe worth checking.
After some research, the stock ej22 turbo ECU works with this swap. I read that the JDM ECU is meant for 100 octane jap gas and there will be knocking and/or detonation .
ECU pin for the CTS had no continuity between it and the sensor. I made a new wire for it. 21 doesn't pop up any more but my car still wont start. How many volt/ohms does crank angle and cam angle sensor test at? Im trying to weed out any other possibilities
Edited by mx4life
Did you find the break in the CTS wire or just bypass it and run a new wire? The reason I'm asking is (for example) if the wiring harness got damaged somehow (got any squirrels or other rodenty type creatures nearby?) other wires in the harness may have also been damaged at the same point.
When you replaced the 02 sensor, did you use the kind you have to splice in or a plug in OEM part? I'm just wondering if you could have exchanged (for example) the +12V supply for the o2 sensor heater and a ground... created a short and taken out a fuse, the ECM etc.
Did you ever verify that the +5 v the ECM sends out to most of the sensors is present? If you've got the pinout for the ECM you should be able to find it. The MAP sensor gets this, the MAF sensor gets it, the TPS, etc. (Most of these sensors have +5, signal output and ground terminals on them.)
The O2the sensor I got was a common part number for this car. It's a 3 wire bosch I had to splice in. I'm sure the signal wire is correct but I was told the 2 heater wires polarity doesnt matter. I'm trying to find a wiring diagram so I can see what else in that circuit.
