stant093 Posted February 26, 2004 Share Posted February 26, 2004 im having a hard time finding the dang wires in my legacy...beginning to wonder if im looking for the right wires....anyway, i need a pic if someone is kind enough of their under side of the dash, removing the kick plate that is under the steering wheel...i need to find out what is wrong with my legacy..... thanks i definatly appreciate it!!!! Link to comment Share on other sites More sharing options...
kevinsUBARU Posted February 26, 2004 Share Posted February 26, 2004 Its really hidden good. When you are on your back looking up, it will be on the radio side of the steering column. Its usually taped to another bundle of wires with black tape of some sort. Just run your fingers along every bundle until you find it. Ignore the green T connectors, you're looking for the black ones. There will be two that snap in to eachother. Do that, then follow these instructions written by Legacy777. Kevin Link to comment Share on other sites More sharing options...
kevinsUBARU Posted February 26, 2004 Share Posted February 26, 2004 And removing the plastic thing under the steering column isn't necessary, but it may make things easier. I haven't ever had any problems getting to the connectors. Link to comment Share on other sites More sharing options...
Legacy777 Posted February 26, 2004 Share Posted February 26, 2004 pics of mine http://www.main.experiencetherave.com:8080/subaru/images/ecuhide.jpg they may be on the other side of the steering column for some of the models Link to comment Share on other sites More sharing options...
stant093 Posted February 26, 2004 Author Share Posted February 26, 2004 well i found the green connectors, now to find the black ones.... if the car is running roughly and i unplug the IAC valve, and it runs alittle better, thats a bad IAC valve right?? Link to comment Share on other sites More sharing options...
Legacy777 Posted February 27, 2004 Share Posted February 27, 2004 not necessarily. If the ECU is getting a signal from another bad sensor which is causing the ECU to poorly adjust the IAC valve.....that would exhibit the same results when unplugging the IAC valve...but the valve isn't the problem. Try to find the connectors and go from there. I had a weird hi idle issue and of course dealer was of no help....traced it down to a little screw on the top of the throttle body which was letting too much air past the TB and was making the IAC useless since it was outside of its operating range to pull the idle back down. Link to comment Share on other sites More sharing options...
stant093 Posted February 27, 2004 Author Share Posted February 27, 2004 well after doing a scan over of the engine, i basically crawled in the engine compartment, i noticed a bit of gasket sticking outof the intake manifold no 4 cylinder, closer inspection reveals a cracked intake...one of the ears broke off from what it looks like.... Link to comment Share on other sites More sharing options...
