Universeman Posted October 19, 2010 Share Posted October 19, 2010 I have an 82 Brat and my cooling fan is not turning on and it is overheating unless I am moving at a good speed. I just connected the fan directly to the battery and it works fine. The haynes manual has very limited info on the thermo switch and before I order parts I wanted to verify that it is the culprit. I just need to know where the switch is and if I can check its operation. Thanks Quote Link to comment Share on other sites More sharing options...
Mykeys Toy Posted October 20, 2010 Share Posted October 20, 2010 It is located on the radiator above the drain. If it is green or clearly oxidized it is probably done for. you can however hotwire it with switched power so it is on all the time with the key. I don't really like that much but I have a car like that now. Mike Quote Link to comment Share on other sites More sharing options...
Universeman Posted October 21, 2010 Author Share Posted October 21, 2010 It's fixed, just forty buck for a temp switch from Napa, works like a champ now. Quote Link to comment Share on other sites More sharing options...
