Sluggish??
Many Reasons could affect the Behaviour of the Engine, when Runnin' on Low RPM's, beside the Vehicle's Weight / HorsePower Ratio, Load, Kind of Road; I can Think on these "Easy Check & Fix" Ideas that Might Help:
  • Bad Timing.
  • Failing Advance at the Distribuitor.
  • Clogged Cat and / or Muffler.
  • Worn SparkPlugs.
  • Low Octane Gasoline.
I Kindly Suggest to do a "Tune Up" Changin' Sparkplugs if they're Old and Check your Subie's Engine Actual Timing Degrees, it Should be Around 20º
Kind Regards.
