gar52hpny Posted October 22, 2010 Share Posted October 22, 2010 (edited) Hello does anyone have timing belt replacement instructions with pictorials for an 2002 outback wagon 2.5 engine type: Ej251axbwl, model:bh9cy4r, vin:4s3bh665527641758 automatic. Also, in addition to the timing belt, what other parts should be changed? Thank you, gary Edited October 22, 2010 by gar52hpny SPELLING Link to comment Share on other sites More sharing options...
nipper Posted October 22, 2010 Share Posted October 22, 2010 All idlers Water pump Cam Seals Main Seal Re-seal Water pump Accesory drive belt Thermostat PCV valve Do an oil change afterwards just because. Do a searhc here on timing belts http://www.lovehorsepower.com/SubaruDocs/TimingWaterPump.htm 1995 http://www.subaruforester.org/vbulletin/f66/timing-belt-pump-change-14416/ forester but same engine Link to comment Share on other sites More sharing options...
gar52hpny Posted October 23, 2010 Author Share Posted October 23, 2010 Nipper, Thank you for your reply. Just to make sure that I am reading this right you are saying that this 95 Forester and my 2002 outback motor have the same timing belt installation instructions? Also, what web site has the best Subaru origional equipment prices for these parts? Thank you, Gary Link to comment Share on other sites More sharing options...
Olnick Posted October 23, 2010 Share Posted October 23, 2010 Those links are for EJ22 engines--your is, I believe, a Phase 2 EJ25 SOHC. Theory should be the same except for a few details (tensioner mounting, tooth count on the belt.) Hopefully someone with EJ25 SOHC knowledge will chime in. As for best price on parts, check a few web sites. Then call Jason, Parts Manager at Mike Scarff Subaru in Auburn WA--866-528-5282. Good guy, always seems to have the best prices. Mention USMB. Good luck. Link to comment Share on other sites More sharing options...
Tahoe Subaru Posted October 23, 2010 Share Posted October 23, 2010 (edited) you tube has a few. this one show how to line up the marks. but he compresses the tensioner to fast and not vertical like the manual says. the DOHC has four cams to line up. the SOHC has two. how many miles on your motor? Edited October 23, 2010 by Tahoe Subaru Link to comment Share on other sites More sharing options...
Tahoe Subaru Posted October 24, 2010 Share Posted October 24, 2010 I've used this site. Nsk, Koyo, Ntn are original equipment. the updated lower right pulley has a lip. same part # from Subaru. http://catalog.importrp.com/resetsession.epc?cookieID=32610RNLW32610VF9K&source=www.importrp.com Link to comment Share on other sites More sharing options...
ocei77 Posted October 27, 2010 Share Posted October 27, 2010 Attached is PDF for engine overhaul. Page 18 starts the t belt replace data. (oops, can't attach file. email me at ocei77@hotmail and I will forward) Go to legacygt.com and search for vacation pix and you can get the entire set. I purchaed my belt from RockAuto. A gates unit for $36. Tip: After lining up marks, put the pulleys back as directed. the lower crank sprocket last. There is a bolt that goes through the crankcase halves in the perfect place to use a screwdriver to line up the bolt hole, so you won't go crazy with slipping marks etc. Don't have too much fun. O. Link to comment Share on other sites More sharing options...
