wisdomwrx Posted October 23, 2010 Share Posted October 23, 2010 Ok, so I own a 1980 brat gl ea71 4 speed manual 4wd. I have the know how and skills along with tools to do a swap. I am pondering on doing an ej22 swap for an early nineties subie. How much work am I looking at. What needs to be changed to allow the swap do I need to make special drive lines to fit in the smaller vehicle? Also do I need to make new motor and trans mounts? Will the newer rear diff bolt in? I'm just looking for some info about this swap specifically. Any know how or tips will be highly appreciated. The reason I am wondering is because I just want more power, I live in the sierra's of northern Cali and the brat barely has the power to keep up speed due to the fact that everything is hills and corners. Thanks Ryan Link to comment Share on other sites More sharing options...
wisdomwrx Posted October 23, 2010 Author Share Posted October 23, 2010 I tried to look for a thread showing someone doing a swap but could not find one. If someone could help me find a good thread on the swap I would be very thankful. Ryan Link to comment Share on other sites More sharing options...
wisdomwrx Posted October 23, 2010 Author Share Posted October 23, 2010 So I finally found a good thread will read up and post questions if I have any. Link to comment Share on other sites More sharing options...
michael appel Posted October 23, 2010 Share Posted October 23, 2010 I have a write up Link to comment Share on other sites More sharing options...
Turbone Posted October 24, 2010 Share Posted October 24, 2010 I have a write up It might help if you attached a link to that statement Link to comment Share on other sites More sharing options...
MilesFox Posted October 24, 2010 Share Posted October 24, 2010 Motor mounts will fit the same, you need a bellhousing adapter and use the flywheel to the 4spd drilled out to fit ej22 crank. other than that its a drop-in, save for the wiring and the fuel pump upgrade. use a fuel pump from any ea82 spfi or mpfi(turbo) a rear diff fits the same as the old one i recommend a 5spd swap to handle the engine. I have driven a ej22 brat with the stock 4spd, and you run out of gear too quick in 1st, and find yourself having to shift too soon and the gearing is all wrong. Plus you will be doing fwd burnouts all day long just trying to drive if you get more than half way into the throttle search about 5spd swaps regarding trans mounts and driveshafts. I recommend an ej22 trans, you will basically follow the rules of a 5spd swap, this saves you the bellhousing trouble. you will have to swap the trans axle stubs from 25 splines to 23 splines to use the brat axles Link to comment Share on other sites More sharing options...
renob123 Posted October 25, 2010 Share Posted October 25, 2010 Motor mounts will fit the same Are you sure about this for an EA71? I had to lengthen the crossmember holes on my EA81. Jacob Link to comment Share on other sites More sharing options...
LeoneTurbo Posted October 26, 2010 Share Posted October 26, 2010 If you have the time and skills to make a few modifications I would highly recommend using the EJ series 5-speed transmission aswell. You will have to fabricate new transmission crossmembers and extend the prop shaft. It also involves fabricating the shift linkage, possibly you will have to 'make' some space (ie. hammering the transmission tunnel). Link to comment Share on other sites More sharing options...
Gloyale Posted October 26, 2010 Share Posted October 26, 2010 Motor mounts will fit the same, you need a bellhousing adapter and use the flywheel to the 4spd drilled out to fit ej22 crank. EA71 4spd is a top mount starter. He will need a 4spd from an EA81 for a direct bolt up W/adapter plate. Or he will need a 5spd from EA82, w/adapter plate, and modified crossmember, shifting, and driveline. Link to comment Share on other sites More sharing options...
thatswhatshesaid Posted October 26, 2010 Share Posted October 26, 2010 http://www.numbchuxconversions.com/Files/EA2EJ.pdf Link to comment Share on other sites More sharing options...
