johnceggleston Posted October 24, 2010 Share Posted October 24, 2010 i needed to replace both front axles on my 97obw, bad boots. i have a donor car with "new" looking axles so my plan was to use them. last weekend when i tried to remove an axle nut i did not have my breaker bar so i used my torque wrench. i set it for the max, 250 ft pounds and when it clicked, i quit. i read a recent thread about using a 3/4" breaker bar and an impact reducer so i went to harbor freight to buy . they had a 3/4" ratchet, but not a breaker bar. so instead o bought an electric impact gun/drill/wrench 50$ and boy is it great. it made short order of all 4 axle nuts and on 2 of the 4 axles it was great to have for the axle puller. it took a while for the hammering to get the axle to move but it finally did. i was surprised that it had more trouble with one of the strut bolts than any of the axle bolts. i also picked up a set of impact deep sockets for 20$, 14mm - 32mm. it was a successful day. new tools, woo hoo! Quote Link to comment Share on other sites More sharing options...
bstone Posted October 24, 2010 Share Posted October 24, 2010 Electric impact? Link!!! I replaced all 4 axles at the garage over the summer and used the air impact. Now that I am back at school and using hand tools my arms are getting stronger but MAN is it a lot harder. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted October 24, 2010 Author Share Posted October 24, 2010 (edited) http://www.harborfreight.com/1-2-half-inch-electric-impact-wrench-45252.html one of the things i learned while using it, putting on my lug nits at the end. it will start to hammer almost before it has applied any real amount of torque. i applied a quick burst to run up the lug nuts. i was concerned i might over tighten them. so i then used my torque wrench to tighten them. in all cases the nuts needed almost a 1/4 turn to reach 90 ft lbs. this was reassuring since over torquing lug nuts has bent hubs for some cars in the past. Edited October 24, 2010 by johnceggleston Quote Link to comment Share on other sites More sharing options...
86subaru Posted October 24, 2010 Share Posted October 24, 2010 i have 1 also from harbor freight , it works pretty good , but do not use it every day Quote Link to comment Share on other sites More sharing options...
StructEngineer Posted October 24, 2010 Share Posted October 24, 2010 I have a cordless dewalt 18v and it works great as well. There are two 18v versions, the heavier one is better. It's only a matter of time before you pop off a stud if you tighten lugnuts with it. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted October 24, 2010 Author Share Posted October 24, 2010 but do not use it every day why not, will it break?? Quote Link to comment Share on other sites More sharing options...
MilesFox Posted October 24, 2010 Share Posted October 24, 2010 I have one for about 5 years now. it has been pretty reliable. one time one of the brushes popped out on me when the cap worked loose, but i just put it back in. there were times where i had to re-tighten the screws holding it together. so far it has never fail me, and i use it quite often Quote Link to comment Share on other sites More sharing options...
bstone Posted October 24, 2010 Share Posted October 24, 2010 It looks great. I'll admit, tho, that I like the workout associated with nuts and bolts. My arms have never been stronger! Quote Link to comment Share on other sites More sharing options...
eppoh Posted October 24, 2010 Share Posted October 24, 2010 I have one but it is not strong enough to get the lower strut bolts loose . I don't think it delivers the torque they claim. Quote Link to comment Share on other sites More sharing options...
bstone Posted October 25, 2010 Share Posted October 25, 2010 I have one but it is not strong enough to get the lower strut bolts loose . I don't think it delivers the torque they claim. I know that feeling! I ended up using a LONG breaker bar. The impact did nothing on them. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted October 25, 2010 Share Posted October 25, 2010 i have the same orange one from there. It wouldnt even budge most of the stuff i do. anyone want it, used like 12 times, comes with case, instruction etc. 25 plus shipping. it is a paperweight in my garage. Quote Link to comment Share on other sites More sharing options...
Allpar Mod Posted October 25, 2010 Share Posted October 25, 2010 For some reason, sometimes a long extension on a breaker bar will break a bolt or three better than an impact gun. I use a Husky Professional air gun that puts out 500 lbs torque max tightening and nearly 300 loosening. There's been a few times that it wouldn't break a bolt but a breaker bar would. The stubborn ones undercar often seem to benefit from heating them. If you don't have oxy, or cannot afford it, MAPP gas works nearly as well. Quote Link to comment Share on other sites More sharing options...
