ABS Light - 97 Legacy Outback
Got the ABS light on my 97 Legacy Outback and the car is up for inspection so I need to remedy this. I understand that in order to get the ABS codes I have to go under the dash, above the accelerator and look for the connector (it's yellow/orange in my case) and then put one of probes in the 6th pin hole. I found the connector but I cannot find the probes anywhere. I laid on my back and fiddled around for a while, but nada.
My OBW is a split-year 96/97. I have some 96 components (like the coil pack) and some 97. Any ideas if there was a change between the two years for ABS?
The connector you're looking at is probably the one for the Select Monitor. The 6-pin diagnosis connector, B82, is usually black. It and the two ground probes are typically taped up to the harness (might just look like a lump), near the connector you found and the green ones.
You probably have either the ABS 5.3 or 5.3i system.
See: http://www.endwrench.com/pdf/brakes/FtSubaruABSS99.pdf
--and--
http://porcupine73.com/pics/diagrammatics/tcu-diagnosis-connector-96-1.gif
--and--
http://porcupine73.com/pics/diagrammatics/tcu-diagnosis-connector-96-2.gif
