It can be. I've seen some engines with relatively low compression bring those numbers up a bit after they've been cranked over a few times. Once the cylinder wall gets lubricated again, the oil helps seal the rings back up. On the other hand, it is just as likely that the low compression is the reason the engine got sat for a long time.
