farmwench Posted October 29, 2010 Share Posted October 29, 2010 Help! Trying to replace vapor separator on '88 DL automatic wagon (trying to get it back on the road after years of sitting). Bought the part through the dealer, but Haynes manuel is no help in actually locating the part on the car. Thought with new filter in hand, I'd recognize it on the car, but no luck. Either I have to remove something to get to the part, or the dealership sold me the wrong part. Haynes says remove interior rear vinyl trim panel on passenger side to get to part; nothing but wheel well underneath that panel. How do I find this thing? Thanks. Link to comment Share on other sites More sharing options...
ruparts Posted October 29, 2010 Share Posted October 29, 2010 Help! Trying to replace vapor separator on '88 DL automatic wagon (trying to get it back on the road after years of sitting). Bought the part through the dealer, but Haynes manuel is no help in actually locating the part on the car. Thought with new filter in hand, I'd recognize it on the car, but no luck. Either I have to remove something to get to the part, or the dealership sold me the wrong part. Haynes says remove interior rear vinyl trim panel on passenger side to get to part; nothing but wheel well underneath that panel. How do I find this thing? Thanks. Hi , NO its where they said, its hides behind a metal pillar there, remove the right rear interior trim panel that goes over the wheel and you will be able to find it, look for the hoses coming from the fuel tank at the bottom and some metal shields that cover it, has about half dozen 10mm bolts and the hose connections to remove. Link to comment Share on other sites More sharing options...
farmwench Posted October 31, 2010 Author Share Posted October 31, 2010 Thank you so much ruparts! You're the first person on 2 car forums who's actually known how to get to this thing. Unfortunately, when I exposed the parts the sad truth became clear: Pence Auto (dealership) special ordered and sold me the wrong part . Back to the drawing board so to speak. I appreciate you taking the time to help me. Link to comment Share on other sites More sharing options...
Cougar Posted November 1, 2010 Share Posted November 1, 2010 (edited) I read about the problem you are having on the Car Talk web site. I think the trouble you are having may be due to a bad fuel pump or possibly a clogged filter under the hood. I had a '88 GL-10 model and there was a filter under the hood near the driver area. Your model may be slightly different though. Does anything under the hood match the part the store sold you? The fuel pumps on these cars do go out after time and can act just like yours does. The engine will run a short time and then die due to a lack of fuel. Edited November 1, 2010 by Cougar Link to comment Share on other sites More sharing options...
ruparts Posted November 1, 2010 Share Posted November 1, 2010 Thank you so much ruparts! You're the first person on 2 car forums who's actually known how to get to this thing. Unfortunately, when I exposed the parts the sad truth became clear: Pence Auto (dealership) special ordered and sold me the wrong part . Back to the drawing board so to speak. I appreciate you taking the time to help me. hi, no problem , glad to help if i can. i have saved several of these , i may have the one you need but not sure. if you send me a PM with your email i can exchange a picture or two and perhaps i have it. did you find out if this is actually what was causing your gas fumes problem? it could be a leak somewhere under the hood. Link to comment Share on other sites More sharing options...
