EJ injector ?'s
KootenayJK
I'm hoping someone can answer this quick, so I don't have to spend hours reading threads on the various Soob boards.
My donor engine is from a '95/'96 2.2, and has 4-hole injectors. My ECU/Harness is from a '91 2.2, and has 1-hole injectors. Can/should I use the 4-hole injectors?
Use the injectors that match your ECU. Always.... unless you do a custom tune (not possible with that ECU) or are running some form of engine management.
You will need to use the entire manifold from the '91 since the 95/96 manifold is OBD-II and will not be compatible with the '91 ECU. There might be some cross-over but safe bet is to stick with the '91 electrical components.
