The H6 Valve adjustment is due per subaru at 105K for an inspection. They are shim over bucket lifters and use a different size shim than all the 2.5 motors. They are the same size has WRX valve shims.
The valves tend to wear tighter and when adjusted I try to leave them on the loose end of the adjustment spec. (to allow for future wear, and overtight valves cause misfires, where as a loosely adjusted valve does not.)
Most times the valve adjustment is still within spec at the 105K mark. In my experience most are still withing spec past the 120K point as well.
Dan
Dan
Tighter- via stem elongation, the valve 'fluting', or seat recession?
Dave
Every engine seems to be a little different - thus why Subaru says to check them at 105k. Sometimes you get an exhaust valve that wears quicker than the other's. I've seen it on 2.2's and 2.5's - H6's are less common but the design is the same on the bucket/shim valve system and the valves themselves aren't any different in design.
Checking them is simple (once you remove the valve covers - which is a messy job being the H6 is so tight) - adjusting them is the hard part.
The wear is on both the seat and the valve face. The stems don't stretch or anything like that. But they get tight and checking them is a LOT cheaper than dealing with a burned valve let me tell you - if you have to have a set of those heads rebuilt..... easily $600 for the machine work alone.
