hush777 Posted November 2, 2010 Share Posted November 2, 2010 I am helping my son and we have no power to the fuel pump. I want to check the relay for the pump but can't remember the location and my wiring diagrams are not much help. Thanks Hush Quote Link to comment Share on other sites More sharing options...
Turbone Posted November 2, 2010 Share Posted November 2, 2010 I believe its under the dash on the left side. Kind of a pita to get to :-\ Quote Link to comment Share on other sites More sharing options...
hush777 Posted November 2, 2010 Author Share Posted November 2, 2010 I checked all those (4) relays and they are all working but none of the wires match the wire he says comes from the pump. Hush Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 2, 2010 Share Posted November 2, 2010 86 DL should be carbed.... It will have a fuel pump control unit instead of a relay (it is the relay) under the dash. Look for a black blox about 2"x3" with a 6 pin connector near the relays or above the hood release cable bracket. The wire going to the pump is usually a blue with red stripe. The control unit will also have a yellow tach signal, black ground wire, and an ignition hot supply (white I think). GD Quote Link to comment Share on other sites More sharing options...
Gloyale Posted November 2, 2010 Share Posted November 2, 2010 Carbed or F.I. If it's F.I. the relay is up ontop of the column, above the ECU. If it's Carbed, the "relay" is a box bolted above the Hood release handle. 6 wires with a 3 diamond "mitsubishi" design on it. Quote Link to comment Share on other sites More sharing options...
hush777 Posted November 2, 2010 Author Share Posted November 2, 2010 Sorry about that my bad, it is carbed. I will look when I get a chance for the control box. Thanks guys. Hush Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 2, 2010 Share Posted November 2, 2010 Incidentally - how do you know you don't have power to the fuel pump? With FPCU cars the pump only runs durring cranking and running (when there is a tach signal). Just turning on the ignition will not power the pump. GD Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted November 4, 2010 Share Posted November 4, 2010 I got my first subaru because of no fuel pump power, it was an 86 GL carbed. My dad had chased the no fuel pump power all through the car, gave up and gave the car to me. I found out that it had to have a tach signal to turn on the pump, checked the distributor and found the rotor wasn't turning. Drivers side timing belt had snapped. So make sure you've got spark before you spend too much time chasing the fuel pump power. Quote Link to comment Share on other sites More sharing options...
hush777 Posted November 4, 2010 Author Share Posted November 4, 2010 He got this car because of head gasket problems. We went through and resealed everything. Got new timing belts and stuff too. GD the car wouldn't start, no gas in the carb. We may have just not let it crank long enough. Also went to put gas in the tank and some A$$ cut the filler hose so he had to replace that also. Hush Quote Link to comment Share on other sites More sharing options...
hush777 Posted November 10, 2010 Author Share Posted November 10, 2010 Checked the wiring while cranking and all is fine. Trickled a little gas in till it caught and ran. Finished up hooking things up and got it ready to bring home for him. Test run it showed a little strangeness in the front end and I check..... Bad passenger side ball joint. More parts then we can bring it home. He is pretty excited about it, his first car. Hush Quote Link to comment Share on other sites More sharing options...
