markjw Posted November 2, 2010 Share Posted November 2, 2010 (edited) I'm messing around with a '89 Dakota I picked up a couple months ago. I bought it knowing it was overheating. It smokes on startup, too. Anyway, I bought this head from JC Enterprises (ebay) , and I'm about ready to install. I have never installed a mail order head before. This one is complete, and advertised as "ready to install".... My question is, should I re-torque the cam bearing caps? What about assembly lube? It looks kinda dry. Anything else I need to do to this head before install? The job is straight forward, as far as the install, and, I'm doing all the other stuff, such as timing kit, new water pump, other normal stuff. I just don't want to miss something. Any thoughts? Edited November 4, 2010 by markjw Quote Link to comment Share on other sites More sharing options...
Qman Posted November 2, 2010 Share Posted November 2, 2010 It never hurts to check torque again. With the roller cams you do need to get oil all over everything to help lubricate untill full oil pressure is attained. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 3, 2010 Share Posted November 3, 2010 yeah that has the look of a fully prepped head. i'd do exactly what Qman said. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 3, 2010 Share Posted November 3, 2010 (edited) It it were me - I would remove the cam caps (keep them in order), lube the cam journals, rockers, and lifters with assembly lube (I use Redline assembly lube), and then retorque the cam caps. That's what I do on the heads I get back from the machine shop. Then you will want to clean the head gasket mating surface with acetone or lacquer thinner (my preference) to insure it is 100% oil free (same with the block). Obviously anti-seize your plugs when you install them. After installation I would dump about 1/2 of a quart of the new oil over the cam and rockers, etc. Then install the valve cover and fill normally. Otherwise it looks good and there's not much to do there! GD Edited November 3, 2010 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
markjw Posted November 3, 2010 Author Share Posted November 3, 2010 Thanks for the guidance, guys...This short box, standard cab mini truck is about as impractical vehicle as any I have ever owned, but it's a cheap and interesting diversion from the subi's I have been wrenching on, non-stop, for the past several yrs. I'll post up some pic's when I get it looking good. Quote Link to comment Share on other sites More sharing options...
markjw Posted December 15, 2010 Author Share Posted December 15, 2010 Here's some Before and After pic's. The head install went pretty good. It runs well. I did some front end work and muffler work, too. Found some new exterior parts and used up two cans of Bumper Coating spray paint. Oh yeah, how about those sweet hubcaps. :brow: Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted December 15, 2010 Share Posted December 15, 2010 Turned out very nice! Looks like a serviceable little truck and clean too. I like your use of the bug deflector to hide the hood damage . GD Quote Link to comment Share on other sites More sharing options...
