dmeucci Posted November 3, 2010 Share Posted November 3, 2010 I decided to put in a push button starter for reasons you can follow on the EJ22 Sudden No Start thread. So here is where I am now. I cut the yellow wire from the IG Switch and ran that into a 40am push button. I then ran that to the terminal #86 on the relay. I then ran the #85 to ground. The relay is under the drivers side dash board. The ground I used is a bolt that holds up the clutch lever that looks like it is attached to the car frame. Maybe I should use something else?? I have a wire from +Battery through a wire fuse 30am that then goes through the firewall into the #30 of the relay. I then have a wire that goes from #87 back through the firewall to the starter solenoid. So all was good for a day and then I noticed when I pushed in the starter I would get a small shock. So I soldered (sp?) the wires where they connect to the various eye and female connectors. The I turned the key and I blew the 40amp starting system fuse in the main fuse box. So I am stumped. I have heard from a few folks that they would put the relay under the hood instead of the dashboard, so I can change that. What about the grounds?? Where is a good place to put those? Link to comment Share on other sites More sharing options...
Ricearu Posted November 3, 2010 Share Posted November 3, 2010 your grounds should be ok, but are you connecting that relay to the solenoid small terminal (i know its kind of a goofy question but im serious) other than that maybe a defective switch, the solenoid should only pull a small amount of juice, so small I have used sunroof and doorlock switches to power them before. I would check to see if the switch or wiring is grounding before the relay. Link to comment Share on other sites More sharing options...
dmeucci Posted November 3, 2010 Author Share Posted November 3, 2010 pole #87 is directly connected to the starter solenoid....... I am awaiting for some 45amp fuse links that I had to order....they come in next week monday. After I get them how or what would I check to see if it is grounding before the relay?? Because I cut the yellow on black IG wire and use that to power the relay would that mess up the ground?? The relay is ground off of pole #85 Link to comment Share on other sites More sharing options...
Hendrik Posted November 3, 2010 Share Posted November 3, 2010 Ok , the very most simple solution for you is a push-button switch between the relay input of the startermotor and the battery postive connection. Every push-button switch for about 5 Ampere will do. And just put the 30 Amp fuse in between this connection to the pos. 12 volt battery conection. That will do. Link to comment Share on other sites More sharing options...
dmeucci Posted November 3, 2010 Author Share Posted November 3, 2010 That seems like an easy solution. But if I am using a relay that has four post I am not sure what goes to what then. It seems I would not need the relay and just put a push button directly between the +battery and the starter solenoid.........right? Link to comment Share on other sites More sharing options...
Hendrik Posted November 3, 2010 Share Posted November 3, 2010 yes , with a 30 A fuse in between Link to comment Share on other sites More sharing options...
Gloyale Posted November 3, 2010 Share Posted November 3, 2010 dmeucci said: Because I cut the yellow on black IG wire and use that to power the relay would that mess up the ground?? The relay is ground off of pole #85 I think this could be part of the problem. You really should have tapped into a power wire for the relay rather than cut the wire entirely. Link to comment Share on other sites More sharing options...
