shep Posted November 8, 2010 Share Posted November 8, 2010 Will 16x6.5 2001 legacy wheels fit a 2006 Baja? Thanks Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 8, 2010 Share Posted November 8, 2010 Yeah the 16"s will fit. Pretty sure the lug pattern is the same for the two of those. Might want to check into that. Link to comment Share on other sites More sharing options...
idosubaru Posted November 8, 2010 Share Posted November 8, 2010 should, bolt pattern is the same. the only issue will be if it got huge brakes that need 17's to clear up front, but i highly doubt that. probably just has typical 00 era dual pots that any 16" will clear. to verify you'd just look up jamal's extensive brake caliper thread here or on nasioc, he goes through all the different brake stuff including which fit under what size rims. Link to comment Share on other sites More sharing options...
