Coolant restriction/flow problem
Just put a new ej22 in my 95 legacy and am having a flow issue. The engine is maintaining normal temp but the lower radiator hose is COLD after more than an hour of run time. The driver side heater core hose is also cold and there is no heat. Advice! Going crazy trying to figure it out. New water pump and thermostat. Could it possibly be a bad pump??
Edited by Eurodevo
I had a similar problem in my daughter's 97 2.2, stone cold lower hose but I think she had heat... I can't remember and it wasn't cold weather at the time.
Temp rose and fell while driving, not a lot but maybe between 1/2 and 5/8 of the way up and never overheated.
New T-Stat and a correct burp fixed the problem.
After 2 years the temp stays steady and NEVER deviates from the 1/2 mark.
Has the T-Stat in yours been changed or is it new from the engine swap? The reason I ask is it would be unusual (but not unheard of) to have 2 in a row bad but the one from the swap could be bad from the beginning.
