Eurodevo Posted November 10, 2010 Share Posted November 10, 2010 (edited) Just put a new ej22 in my 95 legacy and am having a flow issue. The engine is maintaining normal temp but the lower radiator hose is COLD after more than an hour of run time. The driver side heater core hose is also cold and there is no heat. Advice! Going crazy trying to figure it out. New water pump and thermostat. Could it possibly be a bad pump?? Edited November 10, 2010 by Eurodevo Link to comment Share on other sites More sharing options...
WoodsWagon Posted November 10, 2010 Share Posted November 10, 2010 How about you keep to the thread you already started about this same issue instead of starting a new one? Check for plugs in the hoses, hose attachment points, possibly clogged radiator, siezed water pump, or stuck thermostat. It's not rocket science. Link to comment Share on other sites More sharing options...
Suzam Posted November 10, 2010 Share Posted November 10, 2010 Was it a Subaru OEM T-Stat? Did you put it in the correct way? (spring towards the engine) Does the temp gauge stay steady or rise and fall? Link to comment Share on other sites More sharing options...
Eurodevo Posted November 10, 2010 Author Share Posted November 10, 2010 Your right, it's not rocket science but it is being very difficult. Yes, the temp rises and falls a small amount. The Tstat is in correct. Link to comment Share on other sites More sharing options...
Suzam Posted November 10, 2010 Share Posted November 10, 2010 I had a similar problem in my daughter's 97 2.2, stone cold lower hose but I think she had heat... I can't remember and it wasn't cold weather at the time. Temp rose and fell while driving, not a lot but maybe between 1/2 and 5/8 of the way up and never overheated. New T-Stat and a correct burp fixed the problem. After 2 years the temp stays steady and NEVER deviates from the 1/2 mark. Has the T-Stat in yours been changed or is it new from the engine swap? The reason I ask is it would be unusual (but not unheard of) to have 2 in a row bad but the one from the swap could be bad from the beginning. Link to comment Share on other sites More sharing options...
Eurodevo Posted November 10, 2010 Author Share Posted November 10, 2010 Thank you! I just put a brand new OEM tstat in. Had the same problem with the last tstat that was also new but was bought from shucks. Link to comment Share on other sites More sharing options...
johnceggleston Posted November 10, 2010 Share Posted November 10, 2010 i'd burp it again. that's what it sounds like it needs. and if that doesn't help i'd remove the t-stat for a test run and see if it moves coolant then. that should tell you something. Link to comment Share on other sites More sharing options...
