95 EJ18 Swaping to EJ22 problem
So far my friend and i have taken a 93 EJ22 and dropped it into his 95 impreza outback. We put the intake manifold from the ej18 on to the ej22 made sure all the plugs were plugged in and hoses connected, we checked and redid the timing MANY times, and we also checked the fuel injectors.... It wont start. The last thing we did was a compression test, Passenger side:100psi for both, Driver side:70psi. would this actually stop it from starting?
(was already advised about hashes vs arrows on the cam gears this is not the issue)
That's pretty low PSI if those are accurate #s.
What did you do about the EGR valve on the 1.8 manifold? that's the only major difference I can see. Doubt that would cause starting issues but....
Double check the small stuff. All connectors and all intake hoses.
Not sure about this, but is the '95 Impreza OBD-2? The '93 EJ22 is OBD-1.
Yaeh but he's still using all the Imp electronics. Shouldn't matter unless the CAM sprocket is somehow different.
I am pretty sure they are the same so there shouldn't be an issue.
Did the CTS get hooked up? Is it good? Try unplugging it for full rich start.
Did you hold the throttle wide open when you did the compression check?
Was the battery fully charged and the cranking speed the same?
Do you have spark?
Do you have fuel?
Is it trying to fire or nothing at all?
Try a cap full or two of gas down the intake, if it starts for a second or two, you have a fuel problem.
Do you have spark?
Do you have fuel?
Throttle was not open, we do have fuel and we do have spark, it sounds like its firing on a couple of cylinders and pops occasionally. Sometimes it blows air out of the intake.
thats some pretty low compression. might be worth doing a leak down test. find out if its rings or valves giving you those low numbers. when you say pop do you mean backfire?
Possibly a backfire it blows a burst of air back through the air filter but also the sound comes from below the block. We are using aftermarket headers so the sound might be resonating through the exhaust.
you said you checked the cam timing marks, what about the crank timing mark?
the compression being different from one side to the other sounds like timing to me. unless you marked the crank pulley, you can't see the crank timing mark without pulling the pulley off.
hope this helps, sorry to state the obvious.
are you positive it was a good running engine when you got it? did you hear it run? have a good feel from the source?
We have never heard the engine run. We did however use the hash marks on the cam gears as well as the mark on the crank gear, they were all lined up with the 3 white lines on the timing belt.
Is it possible the cam gear on the driverside(side with bad compression) could have come loose?
It was matched with the cover, we have had the tensioner out. At this point the engine is out again we are gonna drop the 1.8 back in for now and break apart the engine completely this time I will post an update if we see anything suspicious.
Thank you all VERY much for your input this is definitely the best forum for subaru iv been on so far you guys rock :).
