how does the 95 subaru impreza l wagon 2.2 engine automatic transmission fully work i would really like too know because my subbie will not go into reverse but i can mess around and get it to go into reverse and it will stay for about a hour then when i go to put it into reverse again it seems like its in neutral and all other gears do work thanx
i can not explain how the trans works, but i can testify that once reverse goes you are on borrowed time. something has caused a problem, wear, damage to the trans and it is not going to heal or fix it self. i drove mine like this for a few m0onths, being very very careful about where i parked. but i eventually found another auto trans.
i guess there is a small chance that the fluid is low and a refill will correct it, but i don't think so if it was a temporary problem it would be affecting more than just reverse. i could not find any rhyme or reason to when reverse would work.
start looking now for a trans. any legacy 95 - 99 auto 2.2L engine.
Edited by johnceggleston
