does a 1998 subaru impreza transmission fit in a 1995 subaru impreza l wagon and does it bolt in the same and does the computer the same
it should as long as neither car has a 2.5L engine. your only concern is the final drive ratio. go to http://opposedforces.com/parts to confirm the ring gear a pinion ratio for each car. you may need the build date of the 95 car. i'm not as familiar with imprezas as i am with legacys. pre- 95 legos had differnt ratios than post 95 legos. i'm sure imprezas followed suit so double check the ratios.
if the ratios are different, you can swap the rear diff as well and be good to go.
Edited by johnceggleston
