97 OBW- program remote entry
How do I program the remote entry for this vehicle? I tried turning on and off the car 10 times (not engine, just electricity) and then opening the driver's door, but that didn't work. There is a OE Subaru remote un/lock that used to work but stopped a while ago because the battery in the remote died.
Thanks!
Figured it out
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button
Press lock (left) button the remotes to be programmed. The door locks will cycle one time.
Exit programming mode by releasing Programming button under dashboard and turning key to off.
