badsocref Posted November 15, 2010 Share Posted November 15, 2010 My 2000 Outback has recently been acting like it has a bad battery (or bad leads). Sometimes I turn the key and just get a click, sometimes I get a couple of slow engine turns, sometimes it starts up just fine. I have checked the battery and leads and they seem fine. If I get a click, and try several more times, the car will eventually start. It will sometimes run for days/weeks with no trouble, but I think it's slowly getting worse. I took it in for service recently, but they could find nothing wrong (I'm guessing it was starting just fine that day). I'm looking for ideas as to what might be wrong. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Olnick Posted November 15, 2010 Share Posted November 15, 2010 Sounds like worn/pitted contacts in the starter solenoid, common problem as cars get up in miles. Try a search for "starter contacts" and you'll find a lot of help. Here's one thread for example: http://www.ultimatesubaru.org/forum/showthread.php?t=105893&highlight=starter+contacts Good luck. Quote Link to comment Share on other sites More sharing options...
nipper Posted November 15, 2010 Share Posted November 15, 2010 Starter contacts. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted November 15, 2010 Share Posted November 15, 2010 How old is the battery? Quote Link to comment Share on other sites More sharing options...
Ross Posted November 15, 2010 Share Posted November 15, 2010 Check the brushes in the starter motor too, I've had more trouble with them than the solenoid contacts. Easy and very cheap to replace. Quote Link to comment Share on other sites More sharing options...
987687 Posted November 17, 2010 Share Posted November 17, 2010 Contacts are the first thing I'd do because they're easy. Also clean all the connections to the starter. Ground and positive on the battery, the positive lead on the starter, and the grounds to the engine, and the power to the solenoid. Bad connection in any of those could cause starting issues. Another problem that I've seen crop up here, and I've had on my GL is the ignition switch. If the contacts in the switch itself are wearing out it can cause a low voltage to the solenoid, enough for it to click, but not enough for it to connect the circuit to start the engine. I just put in a different ignition switch I had laying around. The other option is to add a relay to give power right from the battery to the solenoid. Quote Link to comment Share on other sites More sharing options...
