FlyDive2 Posted November 16, 2010 Share Posted November 16, 2010 What is the best way to remove the passenger side fuel tank sending unit (combo unit with fuel pump) on a 1999 OBW ? I've tried once with no luck, didn't want to break/bend anything without checking with THE experts! Do you have to get the float out or tie it to the main unit? Thanks for any help! Jay Link to comment Share on other sites More sharing options...
davebugs Posted November 16, 2010 Share Posted November 16, 2010 IIR rotating it a bit helps. You just need to "finesse" it out. Link to comment Share on other sites More sharing options...
nipper Posted November 16, 2010 Share Posted November 16, 2010 It is like birthing a cow, carefully. Remove the bolts. Lift out the unit, then move it around, angle it, be gentle with it, but it will come out. If you are generally gentle with it you wont break anything as it is not fragile. Link to comment Share on other sites More sharing options...
94Loyale Posted November 16, 2010 Share Posted November 16, 2010 Yep, Like everyone else said, just turn it, angle it to pull it out. Just be easy with it. You don't want to bend the float arm. Same with going back in. It's an easy job, just takes some maneuvering. Link to comment Share on other sites More sharing options...
