Buick350X Posted November 16, 2010 Share Posted November 16, 2010 OK so our forest is tossing codes having it scanned at Autozone ---------- OK so the ABS light has come on, gone off a few times but back on. Autozone says they can't scan the ABS codes for some reason and it will cost $60 for Belltire to do it. Will a $100 store bought scanner do the ABS and all, saving some money in the long run? Or will it be limited just like the handheld autozone is using??? --------- near 190,000 miles n will probably have it forever, just now starting to need attention. Dunno about these engines, what's the rules on it for when the valves should ever be adjusted, or left alone. Link to comment Share on other sites More sharing options...
94Loyale Posted November 16, 2010 Share Posted November 16, 2010 Just a regular hand held scanner won't get you into the ABS diagnostics. A good Snap On scanner or something of the like might be able to but I'm not positive. My MT2500 won't. The only thing I can tell you for sure that works is the Subaru Select Monitor. Link to comment Share on other sites More sharing options...
johnceggleston Posted November 16, 2010 Share Posted November 16, 2010 i think there is a way to blink / flash the abs codes, but i don't remember how. i'd try a search ''abs* codes'' or ''reading abs* codes''. Link to comment Share on other sites More sharing options...
Scoobywagon Posted November 16, 2010 Share Posted November 16, 2010 There is currently NO aftermarket scanner on the market that will read Subaru ABS codes. I checked as this came up for me a while back. The only option is the Subaru scanner. My Snap-on and Matco reps both came up empty searching for this. Link to comment Share on other sites More sharing options...
bstone Posted November 16, 2010 Share Posted November 16, 2010 I guess it's time for me to write a How To: Read ABS Codes Give me a few hours.... Link to comment Share on other sites More sharing options...
bheinen74 Posted November 16, 2010 Share Posted November 16, 2010 probably better plan for more than few hours. Link to comment Share on other sites More sharing options...
bstone Posted November 16, 2010 Share Posted November 16, 2010 I've already got the info, I just need to put it together. 1 Link to comment Share on other sites More sharing options...
OB99W Posted November 16, 2010 Share Posted November 16, 2010 [...]OK so the ABS light has come on, gone off a few times but back on.[...] Download this: http://www.subaru-car.ru/for1/for_01_chas_11.pdf . See the section "Read Diagnostic Trouble Codes". The diagnosis connector and ground probes are typically taped to the harness under the dash, above the accelerator pedal. Link to comment Share on other sites More sharing options...
Buick350X Posted November 16, 2010 Author Share Posted November 16, 2010 I guess it's time for me to write a How To: Read ABS Codes Give me a few hours.... A for dummies version plz, not just copies of tech manuals Link to comment Share on other sites More sharing options...
bstone Posted November 16, 2010 Share Posted November 16, 2010 Oh I know. It'll be very simple to follow. Link to comment Share on other sites More sharing options...
OB99W Posted November 16, 2010 Share Posted November 16, 2010 A for dummies version plz, not just copies of tech manuals About the hardest part of the info I linked to in post #8 is finding the connector. Link to comment Share on other sites More sharing options...
Buick350X Posted November 16, 2010 Author Share Posted November 16, 2010 I would not of said that if I had found the info quickly n easily in the 30sec I browsed that 200 page pdf file Link to comment Share on other sites More sharing options...
bstone Posted November 16, 2010 Share Posted November 16, 2010 How To read ABS Codes Symptom: Your ABS light is on. The following information is not applicable to all OWBs and may only be applicable to OBD-II capable (96 and above). In order to obtain the ABS codes you will have to use the ABS diagnostic terminal under the dashboard. Step 1) Locate the ABS terminal under the dashboard under the steering wheel. It might be REALLY hidden, so take a long look. It looks like this: and Step 2) Take the two probes that are tapes to the ABS terminal and put them in positions 3 and 6. To find positions 3 and 6 look here: Step 3) Turn the car to ON (not the engine, just the power) Step 4) The ABS light is going to flash. Record the numbers of flashes. Step 5) Unplug the ABS terminal Link to comment Share on other sites More sharing options...
