paulo Posted November 17, 2010 Share Posted November 17, 2010 hey all, i have a 2000 subaru legacy GT, wagon. i've just had the timing belt changed, along with the related parts like the water pump. for those wondering what the costs on timing belts are, mine came in at $850CAD. seems high to me, but i paid it. the dealer quoted be $1,200, so the $850 seemed reasonable. anyhow...i'm now hearing a whining sound, and its driving me a bit mad. i like my car to sound the same, it gives me comfort. new sounds stress me out. i'm only about 50km's into the new timing belt. even the wife noticed it, so its gotta be noticeable. can i get some input on what this sound may be? could it be from the new belt(s) and just needs to loosen up over time? could this all go drastically bad if i just take the wait and see approach? any thoughts from the experts out there will be a big help. thanks in advance. Link to comment Share on other sites More sharing options...
davebugs Posted November 17, 2010 Share Posted November 17, 2010 My first guess would be that they got one of the accessory belts too tight. Link to comment Share on other sites More sharing options...
nipper Posted November 17, 2010 Share Posted November 17, 2010 850 is on the high side but not out of range. Wet the belt(s) with the car running and see if it goes away, If it does it is an over tight belt. Check you PS fluid level as that can make a noise like this too. Does it go away with the ac on? Does it match engine speed? Link to comment Share on other sites More sharing options...
94Loyale Posted November 17, 2010 Share Posted November 17, 2010 It's hard to diagnose without hearing the sound. But It could be the ac tensioner pulley if they don't have the notch on the pulley aligned inside the bracket. I see that about twice a week, lol. Link to comment Share on other sites More sharing options...
bheinen74 Posted November 17, 2010 Share Posted November 17, 2010 there are guides that might have come out of place and rubbing on the belt Link to comment Share on other sites More sharing options...
94Loyale Posted November 18, 2010 Share Posted November 18, 2010 there are guides that might have come out of place and rubbing on the belt There aren't any guides for the timing belt on a phase 2. Link to comment Share on other sites More sharing options...
davebugs Posted November 18, 2010 Share Posted November 18, 2010 Haven't heard from OP. When I reread this title. Wonder what he manes by "timing belt fixed". You'd think it would read something like "timing belt maintenance completed". Link to comment Share on other sites More sharing options...
paulo Posted November 18, 2010 Author Share Posted November 18, 2010 hey guys, once again, i'm super impressed with this board. thank you for all your input. i should clear up my definition of 'fixed'. there was nothing wrong with the timing belt. i just completed the maintenance. the mechanic took it apart, the belt was in good shape, and all the seals were in great shape. better safe than sorry i suppose. the noise, it is more obvious when turning. even when i have the car idling and i rock the steering wheel back and forth, the whine seems to grow an then subside with the motion of the wheel. i did a few circles around a traffic roundabout last night too, and the sound was louder, then subsided as i straightened out coming out of the roundabout. so, not knowing too much, i'm thinking that a belt for the steering could have been put back on too tight? thanks again gents. Link to comment Share on other sites More sharing options...
nipper Posted November 18, 2010 Share Posted November 18, 2010 A slipping or loose PS belt. They are a real beach to replace due to the recomended size. Link to comment Share on other sites More sharing options...
paulo Posted November 18, 2010 Author Share Posted November 18, 2010 but easy enough to adjust? i hope... Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 18, 2010 Share Posted November 18, 2010 Check out this thread, it might help http://www.ultimatesubaru.org/forum/showthread.php?t=116220 Link to comment Share on other sites More sharing options...
davebugs Posted November 18, 2010 Share Posted November 18, 2010 Here's what I do with the accessory belts. I get one 1/2 inch longer than called for on the Power Sterring side (hate taking out the bolts and "tilting" the PS pump to get that belt on often) and I get one 1/2 shorter on the alternator side. What is called for you have your tensioner almost the whole way tight before the belt gets tight. IIR jsut add 5 to the # of the PS belt, and subtract 5 from the alternator belt #. Your parts house should be able to help you with this. Link to comment Share on other sites More sharing options...
ShawnW Posted November 18, 2010 Share Posted November 18, 2010 Some times air cavitates in the power steering pump and its a matter of bleeding the pressure/air from the high pressure line side. It can be very messy but what I do is loosen the banjo bolt, have someone start the car (you better have safety glasses/shield on here!), and then tighten the banjo bolt nearly immediately after the car starts. Fluid is going to start spraying out 95 percent of the time. Shut the car off, degrease, let it dry and see if its quiet. Link to comment Share on other sites More sharing options...
nipper Posted November 19, 2010 Share Posted November 19, 2010 but easy enough to adjust? i hope... yes Link to comment Share on other sites More sharing options...
