No heat in 1800 GL wagon 1982
Most likely the valve or control cable for the Heater,heater valves can stick and cables can pop the clip off but rarely break as they are solid wire inner type.
Heater valves can be swapped even between different makes if need be for the external type located in the engine bay.
  • 4 weeks later...
it should be near your right foot if you are sitting in the drivers front seat.look up to the right of the gas pedel.you might need to remove the defrost tube to see it better. you can open it with some plyers ect to get the fuild flowing through the heater care. kind looks like a siringe? with a steel rod coming out of it. it could be the heater core is plugged.after you have it warmed up feel the small 1 inch heater hoses that go through the fire wall.they should both be warm.if not something is pluged or held shut like the temp switch we talked about. anyway good luck.not a good time to be without heat......bummer,Todd:banana:
