i have 215/70/15's on my 96 OB wagon
would like to use the 225/60/16's from a 02 parts car I got as they are nice yokohamas
fit?
clearance issues?
speedo difference?
the overall tread width is not much more and interestingly the overall inflated diameter is not much bigger than I thought it would be...maybe 1/2-3/4" (due I guess to the lower profile tire)
thanks guys
the 16s are smaller than the 15s. google ''miata tire calculator'' and see.
but both are larger than the stock 205/70/15s that came with the car.
John
Great tire calculator...thanks!
looks like tire clearance should be ok...I am assuming the subaru rims from 96 compared to 02 will bolt up but will try it maybe today and see
Try and see, because often specs don't reflect reality.
I wanted to stick 15" steel wheels and snow tires from my 95 Impreza, on to my 2002 Impreza Outack (that has aluminum 16" wheels). Every spec sheet I read said they would not fit.
Ends up they fit just fine. Just less clearance around the brake calipers, but not enough to effect anything.
You should be fine. The shocks on the legos and outbacks are all the same and will fit a 17" rim with 205/50s. Barely. Ricearu had a set on his lego and the rubbed a little. You can't go any larger though because the spring seat on the strut itself will contact the tire. Sti struts are spaced different, so you can go 18" with rubberbands for tires on those.
You should be fine. The shocks on the legos and outbacks are all the same and will fit a 17" rim with 205/50s..
This isn't really true.
Outback struts are longer, and have more room from Knuckle to spring perch.
Largest you can go on Legacy struts is about 225/55/16 or 225/60/15
You can fit a 235/75/15 or 235/65/16 tire on Outback struts.
