bgambino Posted November 21, 2010 Share Posted November 21, 2010 i have 215/70/15's on my 96 OB wagon would like to use the 225/60/16's from a 02 parts car I got as they are nice yokohamas fit? clearance issues? speedo difference? the overall tread width is not much more and interestingly the overall inflated diameter is not much bigger than I thought it would be...maybe 1/2-3/4" (due I guess to the lower profile tire) thanks guys Link to comment Share on other sites More sharing options...
johnceggleston Posted November 21, 2010 Share Posted November 21, 2010 bgambino said: i have 215/70/15's on my 96 OB wagon would like to use the 225/60/16's from a 02 parts car I got as they are nice yokohamas fit? the 16s are smaller than the 15s. google ''miata tire calculator'' and see. but both are larger than the stock 205/70/15s that came with the car. Link to comment Share on other sites More sharing options...
bgambino Posted November 21, 2010 Author Share Posted November 21, 2010 johnceggleston said: the 16s are smaller than the 15s. google ''miata tire calculator'' and see. but both are larger than the stock 205/70/15s that came with the car. John Great tire calculator...thanks! looks like tire clearance should be ok...I am assuming the subaru rims from 96 compared to 02 will bolt up but will try it maybe today and see Link to comment Share on other sites More sharing options...
jdemaris Posted November 21, 2010 Share Posted November 21, 2010 bgambino said: I am assuming the subaru rims from 96 compared to 02 will bolt up but will try it maybe today and see Try and see, because often specs don't reflect reality. I wanted to stick 15" steel wheels and snow tires from my 95 Impreza, on to my 2002 Impreza Outack (that has aluminum 16" wheels). Every spec sheet I read said they would not fit. Ends up they fit just fine. Just less clearance around the brake calipers, but not enough to effect anything. Link to comment Share on other sites More sharing options...
Xanadu62 Posted November 21, 2010 Share Posted November 21, 2010 You should be fine. The shocks on the legos and outbacks are all the same and will fit a 17" rim with 205/50s. Barely. Ricearu had a set on his lego and the rubbed a little. You can't go any larger though because the spring seat on the strut itself will contact the tire. Sti struts are spaced different, so you can go 18" with rubberbands for tires on those. Link to comment Share on other sites More sharing options...
Suzam Posted November 21, 2010 Share Posted November 21, 2010 Should fit fine, I have 205/55-16's on WRX wheels mounted on a 97 Legacy L wagon. They were also on a 95 Legacy sedan. Never had fit problems on either one. Link to comment Share on other sites More sharing options...
Gloyale Posted November 21, 2010 Share Posted November 21, 2010 Xanadu62 said: You should be fine. The shocks on the legos and outbacks are all the same and will fit a 17" rim with 205/50s.. This isn't really true. Outback struts are longer, and have more room from Knuckle to spring perch. Largest you can go on Legacy struts is about 225/55/16 or 225/60/15 You can fit a 235/75/15 or 235/65/16 tire on Outback struts. Link to comment Share on other sites More sharing options...
Olnick Posted November 21, 2010 Share Posted November 21, 2010 Found this fascinating tire & wheel size calculator that allows you to compare cutaway drawings of various combinations. Just type in the pertinent numbers, including rim width and offset, and you get a side-by-side visual representation of the differences. http://www.rimsntires.com/specs.jsp Link to comment Share on other sites More sharing options...
