True2Blue Posted November 22, 2010 Share Posted November 22, 2010 (edited) difference between 5 mt d/r and rear diff out of 87-89 wagons and the rx 5 mt d/r and rear diff Edited November 22, 2010 by True2Blue Link to comment Share on other sites More sharing options...
True2Blue Posted November 22, 2010 Author Share Posted November 22, 2010 Can anyone tell me the stroke measurement that the Hi Lo arm travels? I know the Arm pulls back and fourth as the operator pulls the Hi Lo lever up and down. I dont have a d/r local and need that travel 1st pull (4x4 Hi) measures "?" 2nd pull (4x4 Lo) measures "?" Measuring origin is "?" (the point the travel is being measured from) Or if someone local has a d/r sittin around or in their wagon and would let me take some quick measurements id greatly appreciate it Link to comment Share on other sites More sharing options...
Gloyale Posted November 22, 2010 Share Posted November 22, 2010 3.9 vs. 3.7 23 spline vs. 25 spline front stubs Obviously part time vs. Fulltime Link to comment Share on other sites More sharing options...
Gloyale Posted November 22, 2010 Share Posted November 22, 2010 It's not much at the rod itself. Each notch is about a centimeter of travel of the rod. The rotation at the hi/lo arm, driven by the rod, above the front diff is only a few degrees. * note* If the hi/lo arm is allowed to rotate too far while unhooked or adjusting you can loose the alignment keys for the shift collar inside, so don't do that. You can rotate it "back" and it will stop against a case bolt, but don't rotate it too far forward. Link to comment Share on other sites More sharing options...
Yo'J Posted November 22, 2010 Share Posted November 22, 2010 Well sure, come on by! I just had the thing apart today too. I dont think its much, if any, over an inch mind you, full range. It might be closer to a half per engagement. I got to pull it again too, but not tomorrow. I need a set of new grommets in my linkages as to find reverse again but I tightened it to work and I might not make it to pap tomorrow. Link to comment Share on other sites More sharing options...
Yo'J Posted November 22, 2010 Share Posted November 22, 2010 (edited) . Edited November 22, 2010 by Yo'J ooops Link to comment Share on other sites More sharing options...
True2Blue Posted November 22, 2010 Author Share Posted November 22, 2010 Perfect! (would you happen to know a 99-2000 foresters spline count (hubs) ) correct me if im wrong ( i dont know rx's at all ) but arnt their transmissions d/r? is it Hi Lo AWD? Link to comment Share on other sites More sharing options...
True2Blue Posted November 22, 2010 Author Share Posted November 22, 2010 I have a wagon coming by tomorrow morning:banana: thanks Abe Link to comment Share on other sites More sharing options...
