Transmission Spline Shaft Counts
Ok, I've searched extensively and have yet to come to a conclusive answer.
What are the spline counts for the various transmission input shafts?
I can find axles by the pageload, but never the input shaft spline counts.
So I want to collect all the info and submit it into the USRM for safe keeping.
I'll give credit where credit is due.
So, fill in the blanks.
EA71 FWD transmission input shaft has __ splines
EA71 4WD transmission input shaft has __ splines
EA81 FWD transmission input shaft has __ splines
EA81 4WD transmission input shaft has __ splines
EA82 FWD Transmission input shaft has __ splines
EA82 4WD S/R transmission input shaft has __ splines
EA82 4WD D/R transmission input shaft has __ splines
EA82T FWD transmission input shaft has __ splines
EA82T 4WD S/R transmission input shaft has __ splines
EA82T 4WD D/R transmission input shaft has __ splines
EA82T AWD transmission input shaft has __ splines
EA82T AWD D/R transmission input shaft has __ splines
ER27 FWD Transmission input shaft has __ splines
ER27 AWD transmission input shaft has __ splines
EJ transmission input shaft has __ splines
I hope that covered all of the options up to the old gen.
Now this is obviously just manuals.
So please, answer as accurately as possible and remember, this info is going to be put into the USRM, so please keep the useless banter and off topic posting to a minimum.
Now I'm going to post some seemingly useless tags for easier referencing for the future.
Tags: Tranny, Clutch Disc, Pressure Plate, XT6, Flywheel
Twitch
Manual trans:
4spd and FWD EA 5spd input shafts, not sure of the spline count, but Small.
All other 5spds use the larger input shared with the EJs
Manual trans Outputs:
EA71 FWD transmission shaft has 23 splines
EA71 4WD transmission shaft has 23 splines
EA81 FWD transmission shaft has 23 splines
EA81 4WD transmission shaft has 23splines
EA82 FWD Transmission shaft has 23 splines
EA82 4WD S/R transmission shaft has 23 splines
EA82 4WD D/R transmission shaft has 23 splines
EA82T 4WD S/R transmission shaft has 25 splines
EA82T 4WD D/R transmission shaft has 25 splines
EA82T AWD D/R transmission shaft has 25 splines
ER27 FWD Transmission shaft has 25 splines
ER27 AWD transmissiont shaft has 25 splines
EJ FWD transmission shaft has 23 splines
EJ AWD transmission shaft has 25 splines
Automatic outputs
All 3spds 23 spline
All 4EAT 25 spline
  • 2 months later...
