doobieryan Posted November 24, 2010 Share Posted November 24, 2010 my dad let my gilrfriend drive his loyale for the winter and the other day she was going up a hill and she said it started losing power until it finally died. it still turns over and tries to sputter to life but wont start. my first reaction would be timing belts, but ive heard a fuel filter can cause some of the same issues. any ideas? snow is here and shes driving my 82 and i get her mustang (woohoo) thanks, Ryan Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 24, 2010 Share Posted November 24, 2010 I Kindly Suggest to Check the Fuel Lines and Fuel Pump + Filter... if Everything is OK, Check the Timin' Belts, Check if the Disty's Rotor is Spinning. If Everything is Allright and you're Sure about That, it could be a Loose Disty Coil's Wire or Maybe the Coil itself went Bad. Finally: Fusible Links. There you have my Suggestions... I Hope those can Help. Kind Regards. Quote Link to comment Share on other sites More sharing options...
doobieryan Posted November 24, 2010 Author Share Posted November 24, 2010 Thanks. Where Are the fuel filters and pump located? Im used to ea81s. I think i might go check it out today and see what's up cause its out of town and i haven't checked it out yet and i got off work early today:banana: Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 25, 2010 Share Posted November 25, 2010 if it is a EA82 engine with Carburetor, the Fuel Pump + the Filter are Located Down under the Car, Nearby the Gas Tank. Search Behind up the Passenger's Side Rear Wheel. More information of your Dad's Loyale Model will be Helpful... Kind Regards. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 25, 2010 Share Posted November 25, 2010 Check the screw in the distributor rotor first then check the timing belt - the passenger side one. Loyale's are fuel injected and it's very unlikely that it's got anything to do with the fuel system. Since it apparently has spark and tries to fire - coupled with the fact that it died while running..... it's a timing belt or a rotor screw..... or it's out of gas. GD Quote Link to comment Share on other sites More sharing options...
doobieryan Posted November 25, 2010 Author Share Posted November 25, 2010 women dont know how to describe whats wrong With cars. It seized up and and now its got a rod knocking. Gettin a new engine for it in the next couple weeks. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 25, 2010 Share Posted November 25, 2010 ...It seized up and and now its got a rod knocking. ... Holy Cow! ... How that Happened? Quote Link to comment Share on other sites More sharing options...
doobieryan Posted November 25, 2010 Author Share Posted November 25, 2010 Idk. I didn't tear into it. I started it up and after about a minute it was knocking pretty loud. Its got oil so Im guessing the pump went bad. Quote Link to comment Share on other sites More sharing options...
