lift and tire size combo pics...
mcbrat
  • 3 weeks later...
1998 Impreza wagon Brighton. 2.2 4eat
- 1998 Forester struts and springs (rears swapped with the original Impreza tophats)
- 215/70/15 Goodyear snow tires
- rear doglegs "adjusted" forward instead of swapping the trailing arm brackets
- 10.5" clearance to the oilpan, 11" to the rear diff.
- rear swaybar currently disconnected, front stock one in use
  • 1 month later...
  On 11/11/2013 at 9:33 PM, thesmith said:
I'm thinking about buying some 15" pug alloys for my unlifted ea82 4wd, what size of tires will fit with no mod (if any)?
Probably something like a 195/55/15 or 185/60/15.  Even then those are around and inch taller assuming your stock tire is a 175/70/13
  • 2 months later...
1996 impreza outback
chopped off muffler
no sway bars
no front or back bumpers
abs delete
no name off road lights
outback trailing arm brackets
04 forester kyb struts and some off brand 185/65/14 snow tires
This is my new baby
I have big plans for her if i can find someone to dig up drawings and specs for a four or two inch lift pretty please lol
  • 4 weeks later...
  • 3 months later...
Sorry for not really adding anything to the thread but I got a offset/back spacing question for y'all.
I just took my SJR lift kit off and am just on forester struts and I still have my 235s on. They stick out way to far for my liking. Wondering if anyone knows what a good backspacing would be for a little bit of poke. Right now over half the tire is past the fender. My wheel specs are 15 x7 3.75 backspace with 1" adapters. I want at most 1 inch of poke. There are some options on summit racing I just don't what what backspace to get
  • 1 month later...
I am doing a 2" lift on my loyale and am looking at new tires but I can't figure out what will fit. Lots of people say they have 27" with no rub on a 2" and others say they have rub from 27" on a 3" lift.
Why the difference? Offset? What would the ideal offset be? Or is it from saggy suspension?
  • 1 month later...
  • 4 months later...
  • 3 months later...
  • 4 weeks later...
How high was your lift? And is it for sale?
  • 5 months later...
Last pick no lift with factory adjustable coilovers Honda Accord coil springs in the rear 195/70R14
Middle pick same coilovers and tire wheels 2" SJR lift
First pick 205/70R15 with a lot of rubing on mudflaps and plastic trim on corner of backdoors
I'm looking at lifting my 87 DL wagon but I dont know which one I want to do. I've looked up the lifting spacers and have been thinking of getting them, but also I've heard of using forester springs to give the car a lift too. which one do y'all think would be the best and cheapest to do. Another subject would be bigger wheels to get cheaper mud terrain tires. what wheel would i get? i know its a six lug but which ones work the best?
  • Like 1
Forester springs or any ej style suspension won't work on your car. You're only option is lift blocks.
  On 11/24/2015 at 5:51 AM, Boy named sue said:
I have got a 97 legacy outback and would love a 3'' lift. Does anyone know what years that Forester or Outback Struts and springs will comply with my ride
98-08 Forester struts and 96-99 Outback struts will be a direct bolt in.
  • 5 months later...
  • 1 month later...
Just got a 96 legacy. Looking to do lift and tires but don't know the best direction to go in. I want to go big but not ridiculous. I saw someone say something about forester or outback struts and springs, how effective/easy is that swap to do? I've also seen lift spacers and king springs. Again just looking for advice.
