xt6 suspension under ea82
86hatchback
I've had a wild hair for a while of the thought of a lowered 2wd ea82 sedan to go rippin through the curves with. Mainly because I found a 2wd xt6 a while back and it's still around.
So my question is does the whole rear suspension swap over from the xt6 to the ea82 or just the rear arms?
I'm assuming all xt6's had swaybars in the rear.
I've read up on swapping the front just hadn't been able to find the rear info.
Thanks
All EA82/XT6s with a rear sway have them mounted to the main trailing arms in the rear. I've also seen people modify the arms to accept a swaybar when it didn't originally come with one.
The main upgrade using the XT6 stuff is the fact you'll have better brakes and a little bit better suspension. I like to use only the parts I have to for the XT6 and then use EJ parts the rest of the way for more upgradable parts.
