ivantruckman Posted November 26, 2010 Share Posted November 26, 2010 I have a 1998 forester, I'm doing a auto trans flush, noticed the fluid is clear, not red. do I have to use OEM ATF fluid at 7 bucks a quart or is dextron 3 a good replacement ?? Quote Link to comment Share on other sites More sharing options...
davebugs Posted November 26, 2010 Share Posted November 26, 2010 I've done a lot of Suby's mostly 95-99. Never seen clear ATF. Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted November 26, 2010 Share Posted November 26, 2010 Use any ATF labeled Dextron 3 in my opinion. It is now sort of an industry quality standard, instead of a brand name product originally for GM cars. I don't think that any brand is better then another. I use the store brand product from Walmart with no problems in both my 98 and 99 OBWs for many years now. IMO, it is pretty much generic stuff. The synthetic ATF may better, but I don't know that I have ever read anything as to why. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted November 26, 2010 Share Posted November 26, 2010 Hmmm... Where did you see clear fluid? Was this on the dipstick? If so, which side of the trans was it on? Or did you drain fluid from the trans? And again, if so, where on the bottom of the trans did you find the drain plug? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 26, 2010 Share Posted November 26, 2010 owners manual is helpful with stuff like this, it just takes standard ATF available at a zillion stores across the country. as to being clear, that's really odd. i've seen some times where ATF just has a different color and doesn't really show up well on the dipstick, it may even appear clear-ish - but it's not when you actually see it/drain it. i would guess that's what is happening here. Quote Link to comment Share on other sites More sharing options...
OB99W Posted November 26, 2010 Share Posted November 26, 2010 One of the best ways to check ATF color is to put a drop of it on a white paper towel or napkin. Quote Link to comment Share on other sites More sharing options...
AWDfreak Posted November 27, 2010 Share Posted November 27, 2010 What they said, Dextron III will do fine on the 4EAT (and also as PSF) However, I heard that the 5EAT requires the Subaru HP-ATF (P/N SOA868V9241). Anyone care to elaborate on that? Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted November 27, 2010 Share Posted November 27, 2010 you might be checking the front diff, not the ATF level. The ATF dipstick is over on the driver left side, hidden away by the heater hoses and starter. The gear oil is over on the right side and a lot easier to find the dipstick. What side did you pull the dipstick from? oh boy. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted November 27, 2010 Share Posted November 27, 2010 The front diff drain plug is also a 21mm head or so, and it goes into an aluminum casting. The transmission drain plug is a 17mm head and it threads into a sheet metal pan. Front diff fill plug/ dipstick is yellow, and mounted down on the transmission on the passenger side of the car. The dipstick is about 10" long and is a solid rod with the end squished flat. The transmission dipstick is on the drivers side, red plastic, and is under the heater hoses by the starter motor. This dipstick is about 18" long and is a flexible flat ribbon blade. Make sure the right fluids go in the right places. Many a subaru automatic has been ruined by people draining the transmission and filling the diff, or draining the diff and filling the transmission. Transmission takes ATF Dextron/Mercon III, front diff takes 80/90 hypoid gear oil. Quote Link to comment Share on other sites More sharing options...
ivantruckman Posted November 30, 2010 Author Share Posted November 30, 2010 once I drained the fluid into a white bucket it was red, but not a dark red. oh well. put in new dex 3 and away we go. woohoo thanks all Quote Link to comment Share on other sites More sharing options...
Oliver_1961 Posted November 27, 2011 Share Posted November 27, 2011 I have a 1998 forester, I'm doing a auto trans flush, noticed the fluid is clear, not red. do I have to use OEM ATF fluid at 7 bucks a quart or is dextron 3 a good replacement ?? Perhaps you are looking at the differential fluid? Quote Link to comment Share on other sites More sharing options...
shortlid Posted December 28, 2013 Share Posted December 28, 2013 OK, so If I am going to drain and refill a 4EAT in a '03 Legacy GT sedan with 95k. Any quality Dextron III product will work. I am going to replace with Castrol Full-synthetic multi-import ATF. Also replacing the spin on automatic transmission fluid filter. Dealer wanted $38 for it got a WIX version for $8! Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted December 29, 2013 Share Posted December 29, 2013 OK, so If I am going to drain and refill a 4EAT in a '03 Legacy GT sedan with 95k. Any quality Dextron III product will work. I am going to replace with Castrol Full-synthetic multi-import ATF. Also replacing the spin on automatic transmission fluid filter. Dealer wanted $38 for it got a WIX version for $8! When you drain and fill, you are only able to drain and refill half of the ATF in the tranny. The other half is in the torque converter, and won't drain out. Your '03 has gone 95K miles on ordinary ATF, so switching now to synthetic is not necessary or that desirable. I drain and fill 3 times with short drives between ATF changes, using Walmart brand ATF with no problems. To me ATF is a generic product. I have never heard of anyone ever having trouble cause by any brand of ATF. It is only when the ATF is not changed after 100K+ miles that it gets old and burnt to cause difficulties. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 29, 2013 Share Posted December 29, 2013 (edited) Synthetic is a bit overboard IMO. Just make sure you use a fluid that meets Dexron III spec and you should be fine. I use the Walmart Supertech brand because its the same stuff as at the parts store for about 1/3 less price. Edited December 29, 2013 by Fairtax4me Quote Link to comment Share on other sites More sharing options...
shortlid Posted December 29, 2013 Share Posted December 29, 2013 The shift quality has deteriated. Hoping full syn and filter change will help. Also ATF WAS changed 30k ago. Quote Link to comment Share on other sites More sharing options...
