Head gaskets leaking oil?
Just got done putting in a resealed EA82 in my 89 wagon , crank it up and its just pissing oil out of the driverside between the head and the block up toward the front of the motor. everything else is dry. I am about sure that the head gasket is bad. Am I on the right track?
Are you sure that its not the seam between the cam tower and the head? there is an o-ring there that seals off the main oil gallery to the cams. There is another o-ring present in the head gasket itself.
it would be more common for the cam tower o-ring to fail.
I think Miles Fox is on to the problem... assure which joint is leaking, the head gasket or the next seal out which would be the RTV seal/cam tower & oil passage "O"-ring. Per your post and # of them sounds like you know exactly what you are talking about.
If it is the head-gasket (I have replaced one do to this but it was 180,000+ miles) and not freshly resealed. If it is newly resealed with new head gaskets then possibly an issue at the joint location... sucks.. but you may not have a choice here.... double, double check...
Edited by Indrid cold
