jsemeraro Posted November 28, 2010 Share Posted November 28, 2010 i have a 96 lsi and i had a truble code 14 for the trany, bad wire so i fixed the wire. now i have more codes. has this happend to anyone else? dose this mean i have a bad TCM? i realy dont want to chase all of the codes and find out that its just the tcm. the new codes are 12,13 and 23. i have a good manual so i know what they are and how to trouble shoot them but would rather just know first. Link to comment Share on other sites More sharing options...
nipper Posted November 28, 2010 Share Posted November 28, 2010 Save us a little work please and post what they codes mean. Can be as simple as a connnector not fully plugged in, especially if they were not there before. Link to comment Share on other sites More sharing options...
jsemeraro Posted November 28, 2010 Author Share Posted November 28, 2010 sry, 12 is solinoid B, 13 is shift solinoid 3, and 23 is engine speed signal. Link to comment Share on other sites More sharing options...
nipper Posted November 28, 2010 Share Posted November 28, 2010 Almost sounds like a harness/plug issue. Link to comment Share on other sites More sharing options...
johnceggleston Posted November 28, 2010 Share Posted November 28, 2010 where and how did you fix the first wire? what caused the first wire problem? Link to comment Share on other sites More sharing options...
jsemeraro Posted November 28, 2010 Author Share Posted November 28, 2010 there was a broken insulation and was grounding so i cut out the bad part and soldered in a new part. this was the number 10 wire from the b55 plug from the TCM, its the common/ground wire for the shift solenoids and inhibitor switch. Link to comment Share on other sites More sharing options...
nipper Posted November 28, 2010 Share Posted November 28, 2010 If you have no driveability issues, reset the codes and go for a drive. Check them again in a week or so and lets see what happens. If you are having drivability issues start here http://www.northursalia.com/techdocs/pdf/transmission/4eat.pdf Link to comment Share on other sites More sharing options...
