desertsubaru Posted December 1, 2010 Share Posted December 1, 2010 I have a 96 OBW with a 94 Legacy 2.2 engine and a 95 legacy wire harness. Which knock sensor should I use? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 1, 2010 Share Posted December 1, 2010 a 1995 EJ22 knock sensor is a 100% fool proof way to make sure it'll work and have the same connector. but i think all the connectors are the same anyway...and probably the knock sensors too for 95 and 96 Ej22 and 25's. Quote Link to comment Share on other sites More sharing options...
capn_r Posted December 1, 2010 Share Posted December 1, 2010 Napa lists the same part numbers for those years so if you have a good one in the mix I'd run it. If you don't have a known good one maybe some more experienced posters will chime in with a recommendation. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 1, 2010 Share Posted December 1, 2010 i got one off ebay i think for like $30 or $40....but i think it was the newer style for the SOHC's. Quote Link to comment Share on other sites More sharing options...
desertsubaru Posted December 1, 2010 Author Share Posted December 1, 2010 I was looking on Ebay and the EJ 2.2 is cheaper then the 2.5. The one I was looking at has the same plug as mine for $21 plus shipping so I will go with that one. Thanks guys:banana: Quote Link to comment Share on other sites More sharing options...
Rooster2 Posted December 1, 2010 Share Posted December 1, 2010 A word of caution.............Upon knock sensor installation, remember to just snug up the bolt. Otherwise, if you really crank down on the bolt to tighten it, you will likely crack and break the plastic sensor and ruin it. Quote Link to comment Share on other sites More sharing options...
